higgledy
My Ruggedliner hard folder is not flush by any means and doesn't fold against the cab for full bed access. But the most water I find under it is a few drips at the corners if I take it through a carwash and water is force fed into it from all sides.
I had a flush looking bakflip for about 9 years and over the long run I found depending on seals and drain tubes was less effective to make it water tight than going to a topmount cover that sheds water naturally before it tries to force its way through a seal. It also gets me an extra inch or two of height which has made a difference in being able to comfortably close it a bunch of times.
