In stock and shipping now, if you have been looking to upgrade to an onboard air system for your airbags with wireless dual path system is the system to go with.
Air Lift WirelessAIR On-Board Air Compressor System - Dual Path (Heavy Duty) 74000
Highlights:
If you're looking for an efficient way to keep your truck's air springs functioning at their best in an extremely convenient package, then the Air Lift WirelessAIR Dual-Path Compressor System should be your go-to solution. This handy system uses a wireless controller mounted in your truck's cab to control a heavy-duty, dual-path compressor system that's that's hooked up to the included wireless receiver. Less wires means fewer hassles when you're keeping your rear air springs filled at their optimal levels to haul your gear, trailers, or toys. The WirelessAIR system allows you to adjust air pressure on either side separately while maintaining adequate pressure for just about any application to keep your ride smooth.
Versatile Digital Wireless Controller
This system is based around Air Lift's unique wireless controller with a dual-path design that allows you to inflate each spring together or separately to get proper load balance in case you're hauling uneven loads. The controller allows you to select the pressure in both of your truck's springs without ever leaving the cab or while outside of your truck to get a good visual on your truck's leveling. The controller comes with a built-in bracket that clips onto your in-cab visor for easy viewing and on-the-fly adjustments. The controller even has the ability to store up to two different pressure settings for your springs that make this system very convenient for hauling jobs that might require varying adjustments on-the-fly due to different weight loads.
High-Powered Air Compressor
The compressor and receiver come with a full wiring harness, mounting plates, and hardware that make it extremely easy to mount just about anywhere on your truck or SUV. The compressor is powerful enough to get your air springs inflated once it receives the signals from the controller. The compressor comes with air lines and is compatible with Air Lift air springs and most other brands of aftermarket air springs.
Warranty Information: Air Lift backs up the WirelessAIR system with a 2-year-warranty.
Highlights:
- On-Board, On-the-Fly Compression Adjustment
- Adjust Air Pressure Individually
- High-Quality Mounting Hardware
- 2-Year Warranty
