Just got a shipment of these in for anyone in the market
2015-2021 F150 4WD King OEM Performance Series 2.5 Adjustable Front Coilovers 25001-367A
Highlights:
You can always trust the folks over at King Off-Road Shocks to create something that can totally change the performance and handling of your aggressive 2015-2021 F150 build, and this set of King front 2.5 coilovers is a leaps and bound improvement over your factory front struts and coil springs. King's OEM Performance Series 2.5 coilovers offer up improved rebound, better compression, up to 25% increased travel, and greatly reduced fade over the stock struts which gives your truck an all-around bump in on and off-road performance. King's coilovers are also able to add a whopping 3.5" of front ride height which allows you to fit big wheel and tire combinations onto your F150 so that your truck gets the ground clearance it needs to go practically anywhere. King's 2.5 coilovers come drop right into place of your factory struts and come with remote-mounted reservoirs and mounting brackets for a bolt-on installation. The reservoirs even feature built-in compression adjusters that allow you to dial in the coilover's ride and performance.Large-Diameter Shock Bodies with Large Shafts and Aluminum Construction
King's front coilovers feature heavy-duty construction with an off-road racing inspired internal design that is then topped off with remote-mounted reservoirs to maximize your F150's off-road performance. The coilovers are each built around a 2.5" diameter shock body that are precision bored and honed with an internal cadmium plating that provides a nearly flawless sealing surface for the valves and piston. The coilovers feature 7/8" diameter shafts and 6061 aluminum pistons that provide incredible reliability. The coilovers have hard anodized 6061 billet aluminum mounts with spherical bearings that reduce deflection for maximum control. The remote reservoirs fitted to each coilover are made out of hard anodized 6063 billet aluminum and use high-quality fittings and pinch-resistant hoses to ensure reliable operation. The compression adjuster is an easy-to-use knob located on the reservoir that allows you to tune the flow of oil going to and from the reservoir to change compression firmer or softer. Each set of King coilovers includes mounting hardware for the reservoirs and are designed to bolt-on right in place of your factory struts and coil springs.
Fitment: 2015-2021 F150 4WD.Returns: King does not accept returns on any of their parts, except in the case of manufacturing defects. Call Stage 3 directly at 623-434-5277 for more information.
Highlights:
- Adds huge suspension performance and handling
- Adds up to 2" of front leveling
- 2.5" diameter coilover with remote reservoir
- Features adjustable compression settings
- High-quality components and construction
- Drop-in replacement for factory coilovers
