2021 F150 4WD ICON 2.5 VS IR Front Coilover Kit 91722
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
2021 F150 STX CrewCab 4x4
Looks like we just got these in stock, ready to ship, let me know if anyone is interested.
Frank
Control arms are also in stock as well, so all parts are in to complete stage 1 or 2 packages.
Icon Packages @ Stage3
Ford F-150 2021 F150 4WD ICON 2.5 VS IR Front Coilover Kit 91722 1636474607771
2021 F150 ICON 2.5 Coilovers Features:
  • Provides excellent handling and performance
  • Pair of complete 2.5 front coilover assemblies
  • 2.5" diameter shock bodies with internal reservoir
  • Features 600lb-in coil springs
  • Digressive valving with 7/8" shaft
  • Billet aluminum mounts with black finish
  • Bolt-on replacements for stock
Adds Awesome Levels of Off-Road Performance with Excellent, Firm On-Road Ride
The stock front coilovers are pretty bog-standard, but they're not built to give your F150 the kind of handling or off-road performance you and your truck may need to head off an adventure. The ICON 2.5 VS Front Coilovers for 2021 F150s give your aggressive 2021 F150 build a massive bump in both on-road handling and off-road performance so that you can take your F150 build to the next level and head off into the wilderness without breaking a sweat. The ICON 2.5s are built from the ground up to give your 2021 F150 a firm, yet controlled street ride while being able to handle violent and consistent impacts off-road so that you make it to your favorite campsite or fishing spot in one piece. The ICON 2.5s also provide 0" to 2.75" of ride height, which can help you get a leveled stance and give your F150 the clearance to fit on larger wheel and tire combinations so that you get the ground clearance you need to handle rough trails or terrain. The 2021 F150 ICON 2.5 coilovers install right into place of your F150's factory front coilovers without the need for any drilling, trimming, or other permanent modifications so that you can get a bolt-on, hassle-free upgrade. 2.5" Diameter Shock Bodies with 600lb-in Spring and Digressive Valving
The ICON 2.5 Coilovers feature high-quality components and features that combine to give your 2021 F150 excellent levels of performance and handling, both on and off-road. Each coilover is built around a 2.5" diameter aluminum shock body that features a larger fluid volume than stock that provides both improved damping and heat resistance than the stock coilover assemblies. The aluminum body also provides improved heat dissipation over standard steel-bodied shocks so that you get less fade during hard off-roading. Each 2.5 coilover is wrapped with a 600lb-in coil spring that provides a good balance of energy absorption and ride quality both on pavement and out on the trail. The ICON 2.5 coilovers feature a 7/8" shaft with finely-tuned digressive valving that can handle extremely aggressive off-road applications without letting you or your 2021 F150 down. The coilovers come standard with CNC machined billet aluminum mounts with black anodized finishes that look great and keep the coilovers attached to your truck no matter how hard you're ripping it around. Each set of coilovers come with install hardware and instructions, giving you everything you need for a bolt-on install.
Fitment: 2021 F150 4WD
For 4WD F150s Only: these coilovers are only designed to fit 4WD F150s. A version for RWD/2WD F150s is here.
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
Still have a few sets of these left in stock but stock has gone down quite a bit, grab a set while they are still available for immediate shipping.
AlxMlr
Alex
Mar 8, 2022
66
37
Orlando, FL
2022 Oxford XLT - 4WD
Wanted to give Frank a shout out, awesome customer service and got me these in a pinch in 2 days! Also ordered the tubular control arms and these all ride great. I know it’s more $ than a spacer lift but holy smokes the ride is way better.
Thanks again Frank!
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
Thanks again Frank!
No problem at all, thank you and glad you are happy.
