JHForman812
Ok guys I am here to help. This ONLY APPLIES to PTS trucks. I am working on something for the key guys too. Im gonna tag in some people here @Puffy929 and @PFXLT so with that said lets dive in!! Ok if you are one of the lucky ones ths firs section will apply to you! Some XLT PTS trucks have the connectors for the footwell ambient lights the drivers side will gray and it will be an open connector on the bracket above your feet like this
ML3Z-1513562-CB full cup holder assembly
ML3Z-14A318-C Media bin light
ML3Z-14A411-C Glove box light
OEM footwell lamp part numbers
ML3Z-14A318-J(front)
ML3Z-14A411-B(front)
ML3Z-14A318-B(rear)
ML3Z-14A318-A (rear)
on the passenger side youll have a black one it will be in a holder
so if you have these adding ambient lights to the foot wells is pretty easy along with adding the cup holder you will have to install a wire that runs from pin 4 on the BCM connector C2280C. this will run to connector C212 pin 30(white connector)
after you add this wire the foot well ambient light connectors will be active. you have to turn on ambient lights in the APIM using forscan.
heres the wire that will be added. I will include it with the cup holder harness if youre an XLT truck.
Ok now for the XLT PTS guys that arent lucky enough to have the connectors. I Have come up with a solution for you too. you must still add the BCM connection. the connection not labeled on here is for a media bin light. the BCM connection is going to be connector C2280E pin 38 and BCM C2280C pin 4
Ok guys, I have redesigned my non connector truck ones. heres the updated version. the 2 connectors that are circled will connect together. the rest go where they are labeled. when you get the harness(or build your own) you have to add 2 connections to the bcm the white wire is C2280E and the red wire is C2280C the black wire is self explanatory its a ground ring terminal. theres a ground post directly beside the BCM.
ML3Z-14A318-B(rear)
