Very good choice, without knowing much more at the moment i would say wheels and tires as well as tint and tonneau as well.The lightning is interesting, but I have not reserved one at this time.
The biggest mod that I would do is purchase light weight wheels to lose unsprung weight. Other mods would be the typical window tint and tonneau cover(solar when available).
The efficiency of the electric drivetrain is so high, that small impacts on it will have a greater effect than on a fossil fuel power vehicle with its extremely poor efficiency.The Lightning wheels appear to be aero wheels, prepare to lose some range if swapping them with aftermarket or factory ICE wheels. Here's an article where an E-Golf loses about 20% of its range after a tire swap:
https://www.roadandtrack.com/new-ca...stickier-tires-impact-an-electric-cars-range/
Cliffs notes version:
https://www.greencarreports.com/new...-can-have-a-huge-effect-on-electric-car-range
Swapping within the Lightning lineup should probably be fine. I also don't know if Ford has released the wheel specs yet, the offset could be different and from looking at pictures the bolt pattern looks the same but who knows.
The E-Golf example above is extreme, aero wheels are supposed to add 1-2% to the efficiency of the vehicle and it looks like they're retained for the test, So it shows how much of a hit is possible not using low rolling resistance tires. How low rolling resistance the Lightning tires will be remains to be seen.
A solar tonneau is going to be a disappointing mod. Photovoltaics are pretty awesome technology but come up two things short to work on the Lightning as a tonneau cover; area and angle, the square footage of the short bed isn't enough to make much of an impact and unless the photovoltaics are pointing directly into the sun, their efficiency drops.
A solar tonneau probably wouldn't even be able to make up for the self-discharge of the battery pack while parked and would very well likely have a negative impact on range if it does anything at all.
Same for wheels/tires as I wrote in another post:
Too bad solar technology is not better at this time.A solar tonneau is going to be a disappointing mod. Photovoltaics are pretty awesome technology but come up two things short to work on the Lightning as a tonneau cover; area and angle, the square footage of the short bed isn't enough to make much of an impact and unless the photovoltaics are pointing directly into the sun, their efficiency drops.
