Wireless Charging DIY!?
Copter
Mar 11, 2021
Toronto, ON
2021 F150 Lariat
brnt
Nov 29, 2020
141
138
UT
'21 Lariat
I went this route:
Ford F-150 Wireless Charging DIY!? 20210315_190755
Ford F-150 Wireless Charging DIY!? 20210315_190528
https://www.amazon.com/dp/B0899Z4YPZ/
It has a built in battery so it will continue charging your phone after you turn off the truck. The power bank gets (slowly) charged from the USB in the cubby (No fast charging? Come on, Ford).
As you can see, the power bank fits nicely. It also has a rubberized ring on the top that grips your phone.
Roady
Cory
Jan 10, 2021
436
667
Northeast PA
2021 F150 XLT FX4
Information Technology
I went this route:
Any issues with your phone sliding off the battery while turning or breaking?
brnt
Nov 29, 2020
141
138
UT
'21 Lariat
None yet, but I also haven't had to make any abrupt maneuvers since installing this setup.
brnt
Nov 29, 2020
141
138
UT
'21 Lariat
I glued an old wireless charger guts to the plastic thing. ??‍♂
Oooo ... I like that. And it looks like there is plenty of space below the removable tray. I wonder if that gap is for the OEM wireless charger available on higher trims.
Now if there was just a higher wattage power supply in the cubby ☹
BoilerTimmay
Tim
Sep 20, 2020
51
602
380
Indiana
2011 SCREW 3.5L
thats what everyone is missing. Wireless charging is slow, and it IS REALLY SLOW when you aren’t using 3amp plugs, so after market won’t be any good except the battery type. Maybe the wiring is under there, but would require cutting.
bratliff3
Ben
Feb 9, 2021
Alabama
2021 F150 XLT 2.7L 302A
I went this route:
I like this a lot, on my other Anker charger I have to press the power button to start the charging once I plug it in. Does this one require that or does it sense once you drop the phone on? Any more feedback after longer use?
LHoffmanjr22
Larry
Feb 1, 2021
172
137
Illinois
2021 Ford F-150 Lariat Supercrew Powerboost
When I’m using my wireless charger in the truck, I’m not necessarily looking to charge quickly, but rather maintain the battery I’m using while doing things like using Apple Maps or Apple Music. My goal is to stop the battery drain from CarPlay, and for that I’ve found that the wireless charger I’ve installed works quite well.
FordConvert
Craig
Aug 11, 2021
141
178
Utah
2021 F-150 Lariat PB 502A
Builder
I am shocked the old USB ports under there put out enough power to support wireless charging at any decent rate. The new USB-C on the '21 should be great for that solution though!
Has anyone found specs on what wattage the USB-C puts out?
Dresdie
Apr 23, 2021
369
250
Ohio
2009 Acura TSX
Thanks. Just realizing the Lariat I have on order *does not* have wireless charging. Disappointing but nowhere near a deal breaker. (First time saying this... c'mon, Ford)
