F-150 Prius
- Adam
- May 12, 2021
- 16
- 530
- 522
- Silicon Valley
- 2021 F-150 Platinum PowerBoost FX-4 6½
- Software Algorithms
Have you experimented with the vehicle sway control?The problem isn't the trucks or their size. In my opinion ford failed on the hitch. Its only rated for 500lbs tongue weight. You can buy an after market with much higher tongue weight load. Using the WDH spreads the weight efficiently. Second is the antisway. Size of a truck won't change that problem. TTs are balanced so that you will always battle sway. That's just a fact. My truck is damn near a 1 ton if you go by the numbers(1944 payload). 20 years ago I may have agreed with but these "1/2 ton" trucks have gotten bigger and better. I am well under all max specs provided by Ford. With the 3.5 inch rake on my truck I only lose 2.5 of those inches without the WDH. The week point is the cheap hitch Ford installed. I mainly use my WDH because it has the built in sway control, not because my truck requires it. The weight distribution is an added bonus.
I'm curious to try it, so far, I've not had enough time towing or a safe situation to experiment, also, I have the Max Tow pack and my triple axle race trailer is well within the envelope. My old 6.0 diesel put up more of a fuss than this "tiny little V6 gasser" : ) … but I think the 150K mile diesel returned better mpg … we'll see once I stop driving too fast and once the Hybrid is fully run in … so far only 7000 miles and very little oil burn, and mpg seems to be getting better for the last 1000 miles.
