I took mine off a couple of weeks ago. They are held on with 3 7mm hex head bolts and on snap in clip. The clip is in a slotted that can be seen when removed. There is a solution to getting rid of the flap however. The Ford Tremor has smooth tim pieces without the UGLY flap hanging down .The Ford smooth replacement part numbers asre as follows ML3Z-99292A23-CA 1X AND ML3Z-99292A22-CA 1X. They are available through Ford Parts and also Amazon/Ebay prices vary from $8 to $12 dollars per piece. Well worth the price to get rid of that cheesey useless flapI kind of figured it has something to do with air. Quite sure when mine arrives I will be taking them off.
thanks for the responses.
yes just airflow reasons the ones for a Tremor dont have that ugly flap on them. they are smooth part numbers are ML3Z-99292A23-CA AND ML3Z-99292A23-CAI kind of figured it has something to do with air. Quite sure when mine arrives I will be taking them off.
ML3Z-9929A23-CA AND ML3Z-992922-CA SORYY ABOU THE FIRST TYPOI took mine off a couple of weeks ago. They are held on with 3 7mm hex head bolts and on snap in clip. The clip is in a slotted that can be seen when removed. There is a solution to getting rid of the flap however. The Ford Tremor has smooth tim pieces without the UGLY flap hanging down .The Ford smooth replacement part numbers asre as follows ML3Z-99292A23-CA 1X AND ML3Z-99292A22-CA 1X. They are available through Ford Parts and also Amazon/Ebay prices vary from $8 to $12 dollars per piece. Well worth the price to get rid of that cheesey useless flap
STILL I GOT IT WRONG ML3Z-99292A22-CA AND ML3Z-99292A23-CA GOT MINE OFF OF EBAY FOR AROUND 9 BUCKS EACHML3Z-9929A23-CA AND ML3Z-992922-CA SORYY ABOU THE FIRST TYPO
yessir I sure did sorry for the error. I was just going to take mine off completely but it has a small hole the a clip goes in.Are you still missing the "A" inside the second number?
No problem...I pointed it out as you were correcting and then you quoted me as I was deleting it since I saw your correction. We are both either too fast or too slow...not sure which.yessir I sure did sorry for the error. I was just going to take mine off completely but it has a small hole the a clip goes in.
Whoa Youve got a ton of points! Use them up while you can!No problem...I pointed it out as you were correcting and then you quoted me as I was deleting it since I saw your correction. We are both either too fast or too slow...not sure which.
I guess I should stop by the dealer and put a tiny dent in my FordPass points. Besides these fender things and maybe the RH swing out bed storage box I honestly can't find much to spend them on. Maybe just load up on filters and other supplies while I'm there...
I agree! unsightly to say the least!I took mine off a couple of weeks ago. They are held on with 3 7mm hex head bolts and on snap in clip. The clip is in a slotted that can be seen when removed. There is a solution to getting rid of the flap however. The Ford Tremor has smooth tim pieces without the UGLY flap hanging down .The Ford smooth replacement part numbers asre as follows ML3Z-99292A23-CA 1X AND ML3Z-99292A22-CA 1X. They are available through Ford Parts and also Amazon/Ebay prices vary from $8 to $12 dollars per piece. Well worth the price to get rid of that cheesey useless flap
