Who are you
The air dam per the Ford repair supervisor from the dealer deploys at 65 mph. Supposedly they received their info from Ford engineering.Small correction - the active air dam deploys at 40 or 45 mph, not 65. You’re entitled to your opinion, but increasing rotational mass by let’s say 30 lbs per corner is huge on a system that already operates on a thin margin to achieve its mpg. Not to mention additional rolling resistance of off-road and wider tires…
I literally just went from stocks to fuel wheels with 34 inch recon grapplers a week ago. At 15,000 miles, I know how my truck performed on stock. I’m down an expected mpg to 21-22 from 25-26. The only reason it’s still high is due to the fact that I optimize my driving for the hybrid and I drive in suburban areas at 30-40mph most of the time. Next time I take my fairly regular highway trip to see some friends with cruise on 75-80, I fully expect to be around 17. Nothing you can do about it when you’ve got all that extra weight to sling around
You are also assuming multiple aspects in terms of thin Margin. If the truck is optimized the way you think Ford would not legally be allowed to say it hits the MPG on different trim levels with different tires sizes. There will be differences but from the legal jargon from the EPA and Ford it has to be within an exceptable margin or face lawsuits.
We have gotten into this before, you have no idea how I drive nor OP, there are two people right now showing similar symptoms and instead of acknowledging the potential of a Ford issue, which have been countless as well as Ford saying QC was terrible, you would rather assume it's anything else. Do you think we are so ignorant and dumb that we haven't tried different driving techniques?
You yourself state you dropped from 25 to 21 , I could accept that. On the high side of acceptable but there. I also wonder if your circumference is dialed in exactly correct, not tire size stated by a converter. but actual mph and distance traveled. 22 ish would be my number to be impressed by with your setup, which seems you do on occasion get that.
I don't travel 75-80 but you assume that. When I travel steady 35-40 I get 15-20 mpg, stock or not, I get best downhill at 55mph (22mpg) and any deviation from that, slight throttle, change in speed up or down and my mpg goes down.
Before you assume, help people. STOP saying it's normal your own experience is different WTF.
