What’s the biggest tow behind camper you would pull with your F150?
120
8,202
9,394
2022 307a PB, Mach E GTPE
So can you turn the ProPower off as default with Forscan or something? Seems like a waste to have that thing run all the time.
Most F150's have a 400w inverter in them. The hybrid's stays in a low power mode when the truck is on, you must switch it into high-power mode. I'd wager it's more efficient idling / creating power than any other version as it's stepping down voltage, not increasing it.
Atlee
Erroll
Sep 14, 2021
1,259
1,303
Mechanicsville, Virginia
Not sure of your question. Pro Power only runs when you want it to run.
JJSnell
JJSnell
Feb 22, 2023
77
1,588
2,021
CdA, ID
2022 F150 Platinum FX4 PB
Like the video above says, it auto starts when I start the truck.
I'll upload a pic in a few.
Ok edited @Atlee @HammaMan
Ford F-150 What’s the biggest tow behind camper you would pull with your F150? 20230406_153045
Ford F-150 What’s the biggest tow behind camper you would pull with your F150? 20230406_153051
If I don't plan on using any of my power outlets in the truck can I just keep this off? By default?
120
8,202
9,394
I can put a clamp meter on it but I really doubt it's going to show anything. It doesn't show up in forscan as having anything to monitor. Hell there's only 3.75% loss on the DC/DC putting out 1.29kW stepping 268.7v down to 14.53v (Though with higher HV voltage, it seems to increase to as high as 9.1%)
turbopilot
Sep 8, 2021
605
904
Prescott, AZ
2023 F150 Powerboost
Bit lengthy but these were are experiences, we did get a smaller microwave. It does struggle with our 5th wheel larger microwave.
Here is a video walk through of my 2021 PB with PPOB 7.2K generator. At 2:58 in the video you can see the ProPower display while it is fully supporting the 25' Airstream with both air conditioners running.
120
8,202
9,394
Hey, I've seen that vid before. Nice rig!
It'd be nice if the PB's inverters had a surge rating on them, but alas, you can have all of its 7.5x kW of generation and that's it.
minirx7
Ed
May 13, 2021
240
168
Toronto
Actually i find it really annoying when it is running as the fan is ALWAYS running unless you turn it off manually. I wish there was forscan to turn it off as i never really use it.
For those looking at the 2kw Gas version, dont bother, its probably just smarter to save the payload and carry a battery back like the ANKER. I bet you the weight of the inverter, the batteries and alternator is about 100lbs which shoudl cover a portable pack that can power an AC.
THe only thing i regret on my truck is the propower and waste of payload compared to carrying an ANKER or something like that.
Something like this!! https://www.anker.com/products/a1780?variant=42353286348950
Ford F-150 What’s the biggest tow behind camper you would pull with your F150? 1680822039557
120
8,202
9,394
Those are powerboost guys conversing -- the only inverters the powerboosts have are under the truck and are water cooled.
minirx7
Ed
May 13, 2021
240
168
Toronto
I'm jealous lol.
10,636
20,537
I don't think the 2k ProPower cost you much Payload?
120
8,202
9,394
Alternator, 2 7ah batts, and the inverter unit itself plus a few pounds of copper. Wouldn't be surprised to hear it's ~42lbs or so.
Jonnyslim
Jon
Nov 21, 2023
30
MI
2021 F150 XLT 3.5
It may not change minds but a lot of folks might benefit from understanding SAE J2807 (the testing scheme that plays a big role in manufacturer tow ratings) and how the different components of that test procedure do or do not relate to their own towing situations.
To that end, IMO this Motor Trend article is worth a read: SAE J2807 Tow Tests - The Standard (though published in 2015 the article describes the standard that is now, with minor revisions, uniformly used by all manufacturers)
I don't suggest that values derived from J2807 are the be-all / end-all for guidance, but it does consider a lot of factors that many might not think about (but probably should), and it does provide a fair degree of comparability when considering the capabilities of different vehicles (both within a given manufacturer's lineup and between different manufacturers).
The actual test standard can be found here:
https://fifthwheelst.com/documents/tow-test-standards-2016-02.pdf
Hopefully it helps a few folks and puts an end to alot of the conjecture. Its pretty comprehensive.
