Welders please school me, is flux welding a few tacks on a crossmember ok?
staying_tuned
Dec 6, 2023
166
192
KY
2023 F150 XLT
Hey folks, I've got a handy little flux welder but have never desired to weld anything on any of our vehicles until now. I've scoured the web and it seems folks say heck no, it can cause damage to the electronics while others say no problem. I'd like to tack weld a few small brackets onto a crossmember. The instructions call for drilling but I'd rather just hit them with a few spot-welds, they won't support hardly any weight so drilling just seems like overkill.
I can fall back on JB weld but reversal would be a mess vs. just a few small tack welds. Is it safe to flux weld on a modern auto and if so, are there any extra precautions I should take?
Thanks in advance for any insight!
79
4,977
5,205
2022 307a PB, Mach E GTPE
The fact you're asking for advice on doing it in itself suggests you're incapable of forming a solid opinion of the question, aka, it's outside your wheelhouse. For low-load, you can use several different bonding agents to make this work without issue. Scuff up both surfaces and make the bond. Yes there is a risk of shorting when welding to a vehicle frame. The risk/reward isn't in your favor.
staying_tuned
staying_tuned
Dec 6, 2023
166
192
KY
2023 F150 XLT
Right on, thanks for the candor!
scott011422
Scott
Feb 17, 2022
30
694
498
60178
I would not do it. Way to many electrical things you would be taking a chance with. Even grounding right to the piece you are welding , Stray currents do odd things.
ks54703
Ken
Aug 15, 2021
130
103
Central Wisconsin
22,XLT,302a,2.7EB,19Escape,87 GLHS 79 Magnun GT
Retired IBEW Local 14 inside wireman
PatchManager
Feb 8, 2022
403
469
Colorado Springs
Firmware Engineer
I do a lot of DIY that most professionals are impressed with because I'm skilled enough, educate myself enough, and I'm not trying to make a living doing it. In almost every instance before I started, I researched and asked for advice. Asking for advice does not necessarily indicate something is outside your wheelhouse. Asking for advice is prudent.
staying_tuned
staying_tuned
Dec 6, 2023
166
192
KY
2023 F150 XLT
Go buy a good set of drill/taps that include the required size thread. Keep a clean install clean. On a vehicle there is never OVER KILL when installing a add on.
I have punch taps & treasured step-bits (hard to find decent ones these days). I didn't mean overkill from a labor standpoint, I'm OCD in that regard. I meant drilling two 1/4" holes for a bracket that will be used to zip secure a simple bump coupler : o )
staying_tuned
staying_tuned
Dec 6, 2023
166
192
KY
2023 F150 XLT
Same here, I took it as outside of my wheelhouse should I choose to remain ignorant on the subject. It is outside of my wheelhouse and I"m grateful that someone set me straight quick before I screwed something up. JB weld is setting now, clamped and encouraged via heat gun.
79
4,977
5,205
Best practice is to isolate any sensitive electronics from the structure you're welding to. All electronics on modern vehicles are full of sensitive components. Again it boils down to a risk/reward and as stated in my first reply, welding low-load tabs onto a modern vehicle makes very little sense. If you're lucky you straight cook a module. That's only $100+ if it's one. If however a module receives damage that isn't obvious, you could be chasing any number of gremlins.
If you're hell bent on having non-structural tabs welded to the frame, take it to a licensed/insured shop so that liability is offloaded.
https://weldingwatch.com/will-welding-on-a-vehicle-damage-electronics/
jeffrt
Sep 21, 2021
130
98
Belle River, Ontario
2021 F150 Lariat, 5.0L
I'd avoid it, personally. You'd need to clear some paint off for the ground cable too. Not worth exposing more bare material than you have to, especially if you have other options.
79
4,977
5,205
JB weld is a perfectly acceptable method here. Doesn't require much at all -- a 1" square area needs a small pea worth of material. Scuff up each area with a 200 grit sand paper, wipe it off with alcohol, apply a little bit of JB weld and tape it in place to cure. You can use other faster epoxies if desired. For removal, use a chisel and give it a good whack with a hamma.
Eighthtry
Boyd
Sep 4, 2023
179
109
Dallas TX
2023 F150 XLT
Drill them. It will look and be a cleaner install.
