WhiteLightningnshitshadow
Nope didn't help. Also removed the coils and cleaned them. No change. Still have a 50-60ish mph vibration in several gears.Did you ever install the shims? If so did it help. I have same issue, removed blocks, noticed about a .75-1 degree shift in pinion angle, a mechanic told me it should hurt anything, but I’m having the same issue with vibrations coming through gas peddle around 45-60 and really prevalent In 7th gear.
