boo radley
Yes. but there must be an aftermarket for gasoline.A quick aside from Titan’s website “Note: For use with diesel fuel ONLY!”
I know Transfer Flow makes a 45 gallon one for the 18-20 F-150. They don’t list it for the 2021-2022, and they don’t explain why. It’s not cheap, and they don’t list the precise dimensions, only that it fits in the same space as the 18-20 fuel tank, so it’s not possible just from their website to see if it could be shoehorned into a Powerboost. It’s also out of stock until next year.Yes. but there must be an aftermarket for gasoline.
Probably because though it may fit, it has to be CARB certified (in addition to the 25 or so other states that essentially run the same regs) for those years to sell it as such. For looser states I bet they'd ship it if you called.They don’t list it for the 2021-2022, and they don’t explain why.
See above, lol. Back in the early 00s it was something like $20,000 to get a part certified, Probably way more now. Plus you had to have a few of the vehicles in basically new condition.It’s not cheap
I would say it's a higher possibility than not, though I wouldn't necessarily be scared of it. Search for something like "F150 won't start parked downhill" on the web and you'll see about the issue of low levels on the large tank causing fueling issues when the front is pointed downhill. Ford has been using this tank for a few generations already.If I understand it, you're saying that the last few gallons (in my case, 5.5 gallons) may not be useable by the truck if I am going downhill? Is that correct?
It's the same for everyone I've seen, and even who have posted here, so I'm sure he's had other people ask. It's not a problem, people have a problem with it.Re: the dealer, he's had multiple people reporting the problem and wants me to bring my truck in,
No, more that people who have an issue with the way Ford has programmed the gauge can change it if they need to.Update: I read the FORSCAN link, and the short answer may be that my truck THINKS it has a smaller tank than it actually has, and that FORSCAN will allow me to inform the truck of its actual tank size.
Same experience here. I know within a ½-1 gal how much fuel I'm going to be getting as the DTE reading drops.21 Powerboost: I have observed that once I get down to less than 200 miles DTE the fuel level gauge and DTE calculation is accurate. I have concluded this based on tank refill gallons. For example with a 50 miles DTE which means something like 2 to 2 1/2 gallons left in the tank, that I refilled with right about 28 gallons. If I refill with a DTE of 200 miles, then the refill is right about 20 to 22 gallons. The DTE calculation changes depending on speed. I live in Wyoming, if I travel on I-80 where the speed limit is 80 mph I get about 20-21 mpg as opposed to local roads where I see about 25-26 mpg. However the DTE calculation above 200 miles DTE is far more variable and I've learned not to depend on its accuracy.
Much easier to legally replace diesel tanks than it is gasoline tanks. I think it has to do with the high volatility of gas vapors compared to the low volatility of diesel oil.There are after market fuel tanks for the 2021 F150. The 3.0 Powerstroke guys have upgraded their trucks.
IIRC, there is at least a 40 gallon tank. One guy change his out in his driveway on a Saturday. Obviously you have to recalibrate the fuel guage.
https://titanfueltanks.com/amfinder?find=2021-ford-f150-4869&sid=76DcM4NvS6
