dkt
Just brought a 2021 with 36 gallon tank. Hit 8 miles to empty fill up only took 31 gallon at fill up. Average 20.5 per gallon only went 618 miles 36 gallon should of went over 720 miles
I've not run my tank below 1/4 tank but noticed the same thing DTE never shows anything over 700, highest I have seen was 660. Is it possible the truck does not know what size tank it has?Just brought a 2021 with 36 gallon tank. Hit 8 miles to empty fill up only took 31 gallon at fill up. Average 20.5 per gallon only went 618 miles 36 gallon should of went over 720 miles
You can check you tank size in Forscan, I will have to find again where the size refence is located....I've not run my tank below 1/4 tank but noticed the same thing DTE never shows anything over 700, highest I have seen was 660. Is it possible the truck does not know what size tank it has?
Tare weight (7 gal gas [42 lbs], running board brackets only, no spare/jack) | 4940 |
29 gal gas | 174 |
Running boards (no brackets) | 23.5 |
Jack + kit | 10.5 |
Spare tire | 61 |
Base Curb Weight | 5209 |
Yes. Based on the weights that I observed, with similar conditions, it pencils out.Are you saying that even though the "50 miles until empty" is displayed, I actually have 8.5 gallons in the tank?
Did you not understand my last two posts? I already addressed the questions you re-asked. If you don't believe my observations or conclusions, then that's fine. Let us know how your inquiry with the dealer shakes out.How does it pencil out?
A quick aside from Titan’s website “Note: For use with diesel fuel ONLY!”There are after market fuel tanks for the 2021 F150. The 3.0 Powerstroke guys have upgraded their trucks.
IIRC, there is at least a 40 gallon tank. One guy change his out in his driveway on a Saturday. Obviously you have to recalibrate the fuel guage.
https://titanfueltanks.com/amfinder?find=2021-ford-f150-4869&sid=76DcM4NvS6
