Snakedoctor
- #136
If I can’t make the one I filed look better I might give this method a try. Worst that could happen is I mess up an already altered oneWhat I ended up doing with mine is separating the molded parts of both the panels and
those melted rivets can be easily cut with an razor knive to seperate the panels. I had the cheap panel with the switches with no rear window switch or openings for sensor. I was able to seperate the panels and use what I needed in order to build one complete panel. In place of the melted rivets I just ran a screw into them since the posts were hollow. Also in addition to the few melted rivets the parts also had clips holding them together. (I know I should have taken pictures) but honestly it was pretty obvious once you get everything apart. you could also use JB Weld or something if you really want it glued but the screws worked great.
