2nd button from the left (next to the auto start-stop button) above your Sync display.Can anybody tell me if there is a way to turn on the rear view camera without putting it in reverse.
like sitting at a stop light to see the car behind you. 360L
If you hit the Pro trailer button. You get more views for behind!Can anybody tell me if there is a way to turn on the rear view camera without putting it in reverse.
I don’t think this shows the reverse cams. Just 360 and the bed. I’ll check on mine.2nd button from the left (next to the auto start-stop button) above your Sync display.
Also button order is not same on every truck/trim. But he means the camera button, and I also don't think it pulls up reverse cam until you do the zoom on the 360 and select the tailgate.I don’t think this shows the reverse cams. Just 360 and the bed. I’ll check on mine.
I'm in the same boat. Only way for me is to shift in reverse. I will try the ProTrailer button.I selected my cams, got to 360, and can see the 360 view, but can’t activate the reverse one unless in reverse
When I hit pro trailer, cameras go off and I get the menu to setup a trailerIf you hit the Pro trailer button. You get more views for behind!
I just click a trailer and it comes up.When I hit pro trailer, cameras go off and I get the menu to setup a trailer
