jjblas
In Sacramento, we had a major storm that toppled a lot of trees and caused power outages all over the county. in our area our power just came on after a 42hr. outage.
I spent a good deal of time going back and forth to a local commercial electrical supply store. I made a 25 foot 10 gauge 4 wire extension cord by use a Leviton L14-30P (male connector) and L14-30R (female connector). The tricky part was making a 6ft. male male pigtail to hook to my dryer outlet (idea was to power both sides of the main). Unfortunately, the dryer outlet is 3 wire so I tied both ground and neutral of the four wire to the dryer neutral.
The Pro Power gave me a ground fault when I first tried to hook up (yes, I made sure to turn the main circuit breaker to the power company off). So, I unplugged the extension and reset what I assume is the circuit light on the truck bed panel (and from the instrument display). I ran the circuit test on all the outlets in the truck with nothing on any of the circuits but still got a ground fault. Since I haven't used any of the circuits at the time, I proceeded to test each circuit by plugging in a cell phone with AC adapter. All A and B circuits worked. I still got a ground fault when testing the circuits.
While the truck may not like what I have done with the pigtail, I could try to not attach the ground and just use the neutral. However, I suspect something amiss with the truck wiring/electronics. I will schedule an appointment with the dealer service.
Any thoughts or advice out there?
