Sucking out fluids is a pretty easy operation. With a rigid container you can make a really simple air powered venturi vac assembly. It's a must have these days to be able to pull fluid out easily with so called lifetime fluids. With modern transmissions I pull 1/3 - 1/2 of its rated capacity out every 30k miles and replace with fresh (varies depending on trans type / use, wet CVTs should be full change every 30k). I've never had an issue with a trans doing continued partial replacements.
