Smitdog
I connected a boat trailer that had some really old / frayed wiring. Connected trailer's 5-way into truck's 7-way adapter, all worked fine initially. Eventually trailer wiring frayed off completely or shorted out, and I received a "Trailer Brake Module Fault" message on the dash.
No big deal, or so I thought. Disconnect trailer, and hit "OK" on message. Didn't work. For the past week I get the error message everytime I start the truck. Also of note, I have a "fast" blinker indicator sound, but all blikers are flashing at normal speed.
In an effort to clear the message, I went so far as to delete the associated trailer profile, checked all fuses related to a trailer (highlighted in red), and disconnected the battery for 10 minutes. Still get the error message and fast blinker sound.
I've read on other forums that disconnecting the battery for 20+ minutes has cleared the fault. I disconnected for 10 minutes, thinking that should be sufficient... But perhaps not long of enough time?
Any ideas? Seems like it would be a simple process to reset / clear.
#42 Trailer brake control module
#55 Trailer tow park lamps
#56 Trailer tow stop and turn lamps
#58 Trailer tow backup lamps
#91 Trailer tow light module
#107 Trailer tow battery charge.
