Towing Question
JJSnell
JJSnell
Feb 22, 2023
62
1,307
1,544
CdA, ID
2022 F150 Platinum FX4 PB
7,000 lb and following the normal rule of scale of 10% tongue weight, means 700 lb on the tongue which would be completely doable for you. I have a Platinum PowerBoost with the sunroof and I think my towing capacity says 1180 if I recall correctly.
In all of the overweighted combos I have seen I've never seen one under a thousand pounds. 700 should be cake.
Edit... Just saw where he said 5th wheel.
F150Eh
Apr 22, 2021
39
Canada, Prairies
2021 F150 XLT
The Powerboost trucks are notorious for low payload ratings, so make sure you check that before buying!
My 2021 Lariat (Non-powerboost) 4x4, SuperCrew,6.5'box, glass roof, 2kW ProPower, with Max tow and my Payload is 1,696lbs. Which with my bumper tow camper hitch weight of 836lbs cuts my people/cargo in the truck down to 860lbs. I know 5th wheels are at or above 1,000lbs on the truck bed...so just be careful there, you might need a limited option XLT to get enough payload for your camper.
Hey Jonathan, does the Max Tow option provide extra payload? I've seen a similar Lariat configuration but with the regular tow package and its payload is only 1300ish. Just curious how you got such a great payload on a Lariat WITH the moonroof! Awesome looking truck :)
Samson16
Kyle
Mar 24, 2023
2,121
1,961
Orlando, FL.
Aviation systems
I looked up several Sundance XLT 5th wheels in the 7,000lbs. dry weight range and all of the hitch weights are between 1,100lbs. and 1,700lbs.
He would have to thread the needle in order to meet specs for sure.
I would move up to a F250/350 or buy a nice pull-behind with a tongue weight below 1,000lbs to pair with a PowerBoost.
Iaflatlander
Iaflatlander
Feb 17, 2024
Iowa
2012 Ford F150 Ecoboost
Short story: you'll be overloaded.
More info: Maybe not on the actual towing weight of the trailer, but on the payload/hitch/pin weight.
Consider the total weight of your 5th wheel hitch, itself. Couple hundred pounds, all in. The mounting bracket, the hitch itself. These are all payload. And the BP lack payload, heavily.
My 2021 PB was a custom build that kept payload in mind. I have a decent payload of 1422 pounds.
My trailer is a bit over 5100 pounds empty. If I assume a loaded weight at a MAXIMUM of 8000# (toy hauler) then my minimum tongue weight is 800#
So that's
1422-800 - 400 (gf and myself) -200 (camper topper)= 22# remaining payload. I'm definitely overladen on payload if I assume that 8000# trailer and 10% tongue. But that's worst case weight.
Since 5th wheels have such a heavy pin weight it would be absolutely no problem to exceed your payload rating. And I wouldn't be surprised if you're overladen with your current truck.
Thanks for the response. Payload is an excellent point. Will be hard to find the right set up.
A cat scale is in my future. I did it when I first set up my 2012, but I'm sure the trailer has gained more weight over the years (I have).
Another observation. Ford has decreased the listed tow capacity in their chart by about 800 pounds since 2021. Wonder what's changed?
Thanks again!
Thanks! I did find my old cat scale on the fifth wheel. On that day, hitch was 1135 lbs. Good call on your end!
madsend81
Aug 30, 2023
75
110
East San Diego County, CA
2023 F150 PB XLT Sport 4x4, 157" WB
Don't forget to factor in the weight of the hitch for the 5th wheel against your payload too.
12Lariat21
Jonathan
Mar 23, 2021
411
497
55374
2021 Lariat 502A
Engineering Manager
My Lariat is Non-PowerBoost/Non-Hybrid, so I likely have the extra 300lbs from the lack of all that, probably should have tried to make my post more clear, because I do have the 2kW propower (Powerboost is 2.4kW base)
As far as max tow increasing payload, not my knowledge it doesn't...I wanted to order my truck with both, but of course you couldn't get the heavy duty payload package in a lariat, also could not order the 3.73 gears with the EcoBoost.
Chiefs F150
Christian
Jan 8, 2024
Alpharetta, GA
2023 Ford F-150 XLT FX4 5.0
No trying to hijack this thread but wanted to find out what size BFGs you have on your rig? I have a 2023 XLT FX4 5.0 super crew short bed in same color and looking to ditch the Hankook's
Not trying to hijack this thread but noticed the BFGs on your rig. What size are they? I have a 2023 XLT FX4 super crew 5.0 in same color and looking to ditch the Hankook's. Always had BFGs on my Jeeps prior to joining the F150 fam and prefer those over Nittos I also ran on a couple Jeeps. Don't like the sidewall on Toyos which seem to be a popular choice in this forum.
12Lariat21
Jonathan
Mar 23, 2021
411
497
55374
2021 Lariat 502A
Engineering Manager
I have the factory size 275/60R20 which is a load D tire. If you go bigger you can only get them in Load E, which are heavier, I like how the truck looks, I do wish I had more tire sidewall sometime, but to go up a size, and drop even more fuel mileage I just don't know if I can stomach that.
Chiefs F150
Christian
Jan 8, 2024
Alpharetta, GA
Thank you!
MetalCord
Dec 14, 2023
37
43
North NV
2023 XLT 302a PowerBoost
IT Specialist
I'll be towing my 5th wheel with my PB once the weather warms up again. I've got a PB XLT with 1648# of payload. My 5th wheel is a little over 5K dry so I should have enough wiggle room to be safe without going on a diet. I'm new to towing so all these threads with advice are invaluable to me. Thanks everyone!
Ranger621
Jan 27, 2022
114
85
2022 F150 Lariat 4x4
Johnathan, what size is your travel trailer? total length and GVWR? Thanks, Chris
12Lariat21
Jonathan
Mar 23, 2021
411
497
55374
2021 Lariat 502A
Engineering Manager
Hi Chris - It's a Forest River, Heritage Glenn 23BHHL
I believe the 23 in the name is for the 23 ft. of living space. Front Bedroom, with a split rear for bath and double bunks.
Total Length = 30'2"
GVWR = 7600 lbs
Dry weight = 5600 lbs
{tpc}
Anthony
Feb 12, 2022
319
163
Berkley, MI
2022 F-150 302a High SuperCrew 3.5 EB MaxTow
GVWR = 7600 lbs
I would venture a guess my salem hemisphere 25 rbhl is similar to your unit. I have almost 1900 lbs of payload, and don't have any issue, but i keep an eye on the tongue weight. Limiting factor for me more than anything else is trailer length. I would not tow anything longer with my truck.
Ranger621
Jan 27, 2022
114
85
GVWR = 7600 lbs
GVWR = 7600 lbs
Thanks for the reply. We just bought a Flagstaff 26RBWS. Slightly heavier but pretty close. I glad to others are towing rigs similar to ours.
Calson
Jul 16, 2022
717
347
Monterey CA
2022 F-150
Unless you know of problems with your current truck I would hold onto it and continue to drive it. 170,000 miles is not a lot and many vehicles have more than 250,000 miles and the original engines and transmissions.
The sales tax and DMV fees on a new truck is going to be more than a transmission rebuild should that be needed. You know what scheduled maintenance is needed for your truck and the probable cost per year and can factor that in against the cost of new truck.
A new truck is not going to be any safer or provide significant gains in fuel economy over your 2012 truck. You may be able to get a larger fuel tank or different gearing and the 10-speed transmission but that is about it.
