rxsamg
- Sam
- Jan 30, 2025
- 3
- 62
- 78
- Marlton, NJ
- 2022 Lariat PB Atlas Blue, 2022 GT500, 1997 SVT Mustang
Having an odd issue with my '22 F150 PB hooked up to an 18" open car hauler that has twin axle electric brakes. Never had this issue with my '12 F150.
After having the trailer sit all winter, I picked it up out of storage for the 1st time using the new truck and pretty sure I setup the trailer options correctly but noticed an odd behavior of the trailer brakes. Everything seems fine during normal braking BUT if I try hard braking or use the controller slider to full braking, the controller seems to switch between full trailer brake power & zero brake power causing a hard jerkiness between the truck & trailer. Best way to describe it is it's like a slow motion ABS on the trailer (like 0.25 or 0.5 second full on, followed by same time amount off)
I have tested: low gain, medium gain, high gain, trailer loaded, trailer unloaded. The exact same symptom happens. It's easily identified by watching the trailer gain monitor in tow status jumping from full gain to zero and repeats ONLY under hard braking or using full slider control WHILE truck is moving. If stopped max brake pressure or slider maintains max gain on meter & doesn't blip down.
I'm going to hook up the trailer to a friend's truck to rule out any issues with the trailer's own brakes/wiring but it's only ~3 yrs old & was working perfectly on my old truck 5 months ago before it sat idle thru the winter. Other option is to swing by my local trailer dealer & test pull a new comparable trailer.
Anyone ever experience similar? Researching I can't find anything showing similar behavior, everything just points to either the controller unit itself or the wiring. I did find a new trailer brake controller recall that supposedly address an issue with the controller software and supposedly it's a fix of a previous recall.
Been trying to search if it's the same behavior but all both recalls indicate are "loss of trailer brake functionality" I'm having a ford tech buddy of mine check OASIS tomorrow, but my truck's build date is 2/2022 might be right at the cutoff of the original recall (if that's even the cause) and Ford's online check of my VIN 1FTFW1ED0NFA63565 doesn't appear to show impacted
Original recall, but can't find if my VIN was impacted
https://www.f150gen14.com/forum/thr...elay-module-campaign-nhtsa-22s17-22v193.9742/
New recall just announced but supposedly only affects 10k vehicles
NHTSA Campaign Number 25V132000 is a recall by Ford Motor Company affecting 10,627 vehicles. The recall addresses a potential issue with the integrated trailer brake control module where the trailer brakes might not engage, potentially leading to longer stopping distances and increased crash risk. This recall specifically targets vehicles that were previously repaired under recall 22V-193 but where the software fix was not fully applied.
