Truman
You are only seeing the B side because the dogbone is only using one leg of the 240 volt plug.....this is all normal. you will only see the A and B light up if you are suing something requiring 240 volts
I received my stubby Camco adapter from Amazon yesterday. Plugged it in to the truck and out 23’ Airstream, turned on the truck and generator, switched the AS from “store” to “use” set the air as cold as I could. Here are the pictures with the air running.
Not sure why it’s only B powering, but otherwise all seems good.
