daemonic3
- Terry
- Sep 22, 2020
- 22
- 1,808
- 1,758
- Sacramento, CA
- 2017 F150 3.5EB
- Engineer
Oh I see what you are saying - you don't have 240V you have 50a with the 4 prongs, which is 2 independent 50a circuits. If you have 50a service in your RV, you've always been able to plug into a 30a pedestal, with an adapter. The adapter will route the one 30a circuit (3 prongs) to both hot legs of the 50a cord (4 prongs). That's why your RV everything will still work, but you cannot pull more than 30a simultaneously. This is a very standard limitation and known to most campers when booking a campground where they are out of 50a sites or don't have any at all. We do it all the time!I was asking about the power port on the camper.. a camper that size should have a 240v/30amp plug in .. which goes to a breaker panel and just like your home, divides the power up to 120v. its basically plug and play...it may need the adapter, I have both .. as I have been to campgrounds that only run 30amp, where my camper is wired for 50.
For the generator plug, you need the adapter that takes one of the 120V 30a circuits to create a 3 prong 30a plug, then adapt again to your 50a plug. This is what I will be doing.
As far as I know, there is not an adapter that can phase align the generator's two 120V 30a phases to make a single more robust 120V 30a (theoretical 60a) output. It would short out the inverter. So you run knowing the limitation that your RV is connected to single 30a service, just like at many campgrounds. You will be able to run nearly everything, except dual A/C, or A/C plus say a vacuum or coffeemaker. (Actually once the A/C is steady state you can make a coffee, but if the A/C has turned off, you better not start a coffee or electric kettle because when the compressor kicks on you will trip - turn off the A/C first)
