In stock in both block and silver if anyone is interested.
Thule 500XT Xsporter Pro Adjustable Bed Rack System 500XT
Adjustable-Height Bed Rack System that Doesn't Require Drilling
Many bed racks out there on the market require drilling into you truck's bed rails for installation, or aren't adjustable which severely limits your truck's hauling capabilities. The Thule Xsporter Pro Adjustable Bed Rack System is the last bed rack that your haul-ready truck needs. The Xsporter Rack System installs onto your bed rails using a specialized clamp system and doesn't require drilling, cutting, or other permanent modifications. The Thule Xsporter Rack even features adjustable heights, allowing you to match the height of your cab for hauling large ladders, canoes or other gear, or drop it below your cab to better keep your gear out of the wind. The Thule Xsporter Rack is built tough, and can handle heavy loads or hardware so that you don't have to sacrifice cargo for convenience. Heavy-Duty Aluminum Construction with Aerodynamic Design
The Thule Xsporter Pro Rack System is made out of high-quality materials and was carefully designed to clamp onto the bed rails of practically any truck on the market. Both the horizontal and vertical bars of the Xsporter Pro Rack System are made out of heavy-duty aluminum and utilize Thule's AirTrip™ aerodynamics technology that minimizes drag. Thule's rack also incorporates WindDiffuser™ technology to produce a quiet ride, even at freeway speeds. The clamps that hold the rack to your truck are extremely heavy-duty and feature Thule's SecureLock One-Key Cylinders that make sure your rack doesn't wander off when you're not looking. Adjusting the rack's height doesn't require any tools, making it simple to adjust the rack for whatever load you have in mind. The Thule Xsporter rack can handle up to 450lbs of load and comes with installation instructions and hardware.
Max Load:450lbs
Height Adjustability: the minimum height of the rack will vary based on year, make, and model due to differences in truck bed depth and position of the horizontal bars in the bed.
Factory Bed Rail/Cargo System Note: this rack system may not fit properly on vehicles equipped with OEM tonneau covers, bed rails, or cargo systems.
Thule Accessories: this rack may require Thule adapter parts for some Thule attachment accessories.
Max Load:450lbs
