I had a similar experience but luckily didn't strip the torx heads out. Once the bolt was out noticed they overdid it on the thread sealant quite a bit. I ran the bolts through the wire wheel a couple times and the went back together with no issues.I had a Zee Dee damper and switched to the Ford for that reason. I didn't want to lose the cleat.
One thing that got me though was when I tried to remove the old hinge, I stripped both Torx bolts. They were on so tight the bolts essentially popped and stripped. I had to cut them out and order new Torx bolts and a new retainer plate because I couldn't extract the bolts from the plate either. I finally gave up trying to extract them and just ordered new bolts and plate....I hope yours isn't so bad if you go this route.
This is what you want.
https://parts.ford.com/shop/en/us/suspension/chassis-parts/damper-assembly-13289007-1
Thanks for the link. Been looking for what will work while retaining the cleat. What side does this mount on? Do you mean passenger side (i.e. right side)? I have a Swingcase tool box installed on passenger side. Not sure this would work with that so I am hoping it can be installed on driver side. Thanks!I had a Dee Zee damper and switched to the Ford for that reason. I didn't want to lose the cleat.
