T6 5-40. MPG
Infotroll
Mar 25, 2021
219
99
NH
F 150 2022
So I went from ford 5-30 to rotella 5-40 and lost 3-5 mpg . I have about 4000 miles on the T6 same driving conditions . So the argument I have heard is that is better for the engine but at the cost of mpg . After doing some math its more expensive to use the 5-40 even at 50% cost of the 5-30 so I will be going back to ford 5-30 . Anyone out here have any thoughts
nrmedic
May 13, 2022
126
160
NC
2022 F150 PowerBoost Rapid Red 302A Sport FX4
I had debated doing something similar, but with QSFS 5w40 Euro which is almost a 5w30. Guess I won't now.
Gros Ventre
Nov 13, 2021
1,086
653
Western Wyoming
Powerboost
Bearings are designed for the specific weight of lubricant. In my Navy service I have seen components with bearings designed for water lubrication. When you up the weight of oil you up the internal drag on the engine. Is it better for the engine? I don't think so. The single thing you can do to improve the engine performance is better filtration. Get a main filter with the lowest micron rating you can find and stick with it. Consider adding a bypass filter.
TruckBubba
John
Jun 6, 2023
Norther Virginia
2020 Mustang 2023 F150
Maintenance Specialist
Way back in the day when I drove worn out old air cooled VW's I used Castrol straight 40W which helped control oil usage, smoking, etc. Now I do follow Fords recommended viscosity and change intervals. They do design engines to work with a specific oil and the only change, IMO, that truck owners should make in that regard is interval change and the use of full synthetic oil.
Plus, I wouldn't put it past Ford to deny a warranty claim if they could prove use of incorrect type motor oil.
Buyer2021
Feb 9, 2021
1,210
2,068
TX
retired!
As they should in the case of an oil-related claim, IMO.
IMO folks need to remember that in modern engines like the current F150 5.0 the oil is critical to a lot more than just bearing lubrication - it also is the actuating fluid / metering force for injectors, VCT, hydraulic lash adjusters, etc.
It's almost assured that all of these systems (their many passages, orifices, bypass / pressure relief mechanisms, etc) are engineered for and to some degree sensitive to the specified oil viscosity characteristics; it shouldn't be surprising that deviating from that viscosity spec may have unanticipated and potentially detrimental consequences.
Ford F-150 T6 5-40. MPG 2022 5.0 oil flow diagram
Calson
Jul 16, 2022
533
263
Monterey CA
2022 F-150
There is something wrong with your presumption that changing the motor oil resulted in a 15% decrease in fuel economy. Something else changed or you did not fill the tank and drive a hundred miles and then refill the tank to check actual fuel burned.
Roush Auto Detailing
Trent
Sep 9, 2022
27
37
North Carolina
2021 Ford F150 302A XLT PowerStroke
Manufacturing Team Lead, Professional Auto Detailer
I use 5W-40 and have been since the first oil change and I did not see that large of a drop in fuel economy. Maybe 2 mpgs. Ford has a spec for use on 5W-40 oil. They say to use it when you are towing or hauling consistently and when you don't get below 0 degrees F; which I pull my detail trailer multiple times a week and our camper multiple times a year and don't get below 0 often in Western NC.
