LarryIT
- Sep 3, 2022
- 1
- 16
- 4
- UP Michigan
- 2022 Ford F150 Lariat
I had this same issue. Called the Ford support line and she had me hold down a couple of buttons on the front of the entertainment system to reset the Sync 4 system (I think it was the power button and next button). This did not clear the SVS problem. She said she would escalate the case and someone would call back within 5 business days. In the mean time, I set up scheduled updates after reading some other posts that said that some of the updates will need this on in order for them to download and install (I have not gotten any indication that anything has updated since setting this up). I also noticed that while my truck was sitting in the garage that one fog lamp was on and the other was off. I could turn them both on, but when I shut them off, the one would stay on until the lights timed out. At this point I decided to pull the negative cable off of the battery (and also the one that extends from the negative wire and bolts to the metal in front of the battery). I let it sit for an hour and hooked everything back up. This didn't solve my fog lamp issue. The only thing I can think of is that it turns on because I get very close to stuff sitting in front of that side of the truck and its alerting me to it and turns the light on to show it in dark garage. I unfortunately didn't check the SVS error after connecting the battery back up (I got distracted with other things). Yesterday Ford rep contacted me and said to take it to the service department at the dealer. He would not speculated on the problem and would give no clues to what it was. At that point I decided to check and make sure that the SVS error was still there before scheduling an appointment. The error is gone. Sorry that I don't know what cleared it, but there maybe some clues in things that I did that may help. It may be something like the truck needs to be powered up and back down a few times after resetting the Sync 4 to clear it or maybe removing power for a while did it.
