WhiteLightningnshitshadow
The metallic kinda makes the color change with the lighting and surroundings more so than other colors. Might consider removing the rear blocks at some point.
Stunning!! Hope to get an update if you remove those rear blocks.The metallic kinda makes the color change with the lighting and surroundings more so than other colors. Might consider removing the rear blocks at some point.
Yeah I think they're flat 1.25in which makes me think there's no pinion angle adjustment required in removing them. Tempted to try it temporarily and reinstall before moving across the country again.If it's max tow, that'll effect squat when loaded.
Since you're FX4, you def. have the 1.25" stock blocks in the back, there's 1" blocks on ebay and I know I've seen 1/2" blocks before, just can't remember where, they are designed to "stack" which I wouldn't recommend, but if you're just sticking a 1/2" piece of steel in there by itself, it would lower the rear a bit for you and still give you some rake I'm sure.
F-150 looking sharp! Hope you love it just as much as we do.The metallic kinda makes the color change with the lighting and surroundings more so than other colors. Might consider removing the rear blocks at some point.
