SpaceWhiteF150
- Sep 18, 2021
- 59
- 1,851
- 960
- Montgomery, Texas
- 2021 F150
- #31
The way the truck sits height/width.
I know it’s showing almost perfectly level but I did tire rotation yesterday. The front still needs to settle. Trust me on ~1in of rake
Tire poke front then Rear
From the front it is not showing full poke, the front wheel is slightly turned
Rear
Front suspension angles
Angles are fine, maybe not perfect but they seam perfectly fine for a extended period of time with use on the truck. The truck is 2wd. It’s sitting on 4wd 2018-20 Bilstien 5100s on all four corners with Toyo AT3s in 285/75r17 wrapped around Venomrex 602s. The fronts are set to factory height(no lift). That got me ~3in in the front and ~1in in the rear. How it did that with the fronts at on the lift no lift setting, I have no clue. The first time I installed them at the max height I got ~6in in the front. How that’s possible, no clue. Why did I install 4wd struts and shocks on 2wd truck? According to research a factory 4wd strut compared to a 2wd strut the only difference is 1/4in so I was thinking that would get me to 2.5in of lift compared to the 2.1 advertised and the Bilstiens in the rear on a 4wd kit would just get me a longer shock in case I wanted to add blocks at a later time. The truck drives, handles, corners, tows amazing compared to stock.
That’s how the truck sits and what I thought through and what it took to get it there. Everything was installed by me suspension wise except professional alignment and tire balancing. Good luck modding!
Rear
