GEM1
Works for us. About 5 minutes to fold the SoftTopper back and get two roadbikes out and put the wheels on. I think it should work on the '23. I'm 6' and my wife is a foot shorter, so the smaller bike kind of tucks nicely under the handlebars. I moved the mounts closer since I took this picture with the bikes a few years ago. Probably could do the same kind of thing with the mountain bikes
I tried to use Rivnuts to hold the channel, but the sheet metal is doubled so that it would not work in some locations. Stick your head under and you will see the problem. So where I hit the double I just used a nut and washer
on the back side. Rivnut on the other one. I spent way too much time worrying about it, and finally just drilled a pilot hole! Figured that's just where it had to be.
