Mjackson704
Are those 315 70 17 ridge grapplers and do they rub?
No they are 35x12.5x17. Bilstien 6112 top setting. zero cutting or scraping. Crash bars untouched. Recon grapplersAre those 315 70 17 ridge grapplers and do they rub?
Thanks so much! I went with the aluminium rough country 2" level up front. I too went back and forth about what tire I should go with. In the end I went with the 275/70/18 as I wanted a bigger tire, but not a super wide tire with a lot of rolling resistance. I liked the way the Tremor's looked, and decided to go with the grabber Atx as I figured they wouldn't be super noisy since they are OEM on the Tremor. They ride great and very low noise. I'm not trying to build a tremor clone, but seem like to like the whole tremor set up, and have been keeping an eye out for the tremor side steps as well, even though the ones I have work great.So I ordered a leveling kit and kept trying to decide what tire size to go with. I researched a ton and couldn't find your exact setup. I thought about keeping stock tires and said screw it. I ordered 275/70/18s with the exact rim you have. I have to say it was the right choice. Awesome look you have. All you need now is the tremor side steps. I'm trying to get me a pair as we speak. So you did me a solid by posting your pics. I may have missed it but what brand of kit did you go with
I like it alot. I have a different set of raptor wheels. I want a set of 6112's. How do they ride on the top setting?No they are 35x12.5x17. Bilstien 6112 top setting. zero cutting or scraping. Crash bars untouched. Recon grapplers
What engine do you have and did you lose MpgThanks so much! I went with the aluminium rough country 2" level up front. I too went back and forth about what tire I should go with. In the end I went with the 275/70/18 as I wanted a bigger tire, but not a super wide tire with a lot of rolling resistance. I liked the way the Tremor's looked, and decided to go with the grabber Atx as I figured they wouldn't be super noisy since they are OEM on the Tremor. They ride great and very low noise. I'm not trying to build a tremor clone, but seem like to like the whole tremor set up, and have been keeping an eye out for the tremor side steps as well, even though the ones I have work great.
Actually pretty damn good. I had 5100s on my last truck and these seem to have more dampening. Softer ride. Price is also pretty good compared to competitors.I like it alot. I have a different set of raptor wheels. I want a set of 6112's. How do they ride on the top setting?
2.7 I haven't calculated it by hand, but going off the trip computer I'm loosing at the most about 1.5 miles per gallon, maybe even a little less. Which is acceptable I think.What engine do you have and did you lose Mpg
I like. I have the stock tire size also. Mickey baja boss 275 60 20. I was thinking of only going 1.5 in front. Do you have pics of it before removing blocks?Bilstein 5100's front, set at 1.5" lift
Removed 1.25" blocks in rear (installed air bags, airlift 5000)
1" total rake front to back. 39.25" front, 40.25" rear
BFG KO2's in factory size, 275/60R20
I did a before and after post here: https://www.f150gen14.com/forum/threads/anyone-remove-rear-blocks.3779/I like. I have the stock tire size also. Mickey baja boss 275 60 20. I was thinking of only going 1.5 in front. Do you have pics of it before removing blocks?
Wow, its stunning! Those rims are epic.2inch rear drop shackles w/ Vossen rims and Michelin defenders 305/45r22
perfect!1.5" motofab level. Still has some rake but took enough out for my liking. Stock size Toyo OC AT3
Looks epic man! Do you have a picture from directly in front or behind to show the offset? I have similar width tires and thinking of going with a larger offset than factory, but didn't know if my current width would look skinny with the offset, but also don't want to buy wider tires lol. Again, sharp truck!Just completed the leveling kit on my '23 PB w/tow package. (not max tow). Truck is basically level within 1/2" on driver side and a 1/4" on passenger side. No rubbing
Suspension: TeraFlex Falcon Sport, SPC UCA, Set front at 2" setting but getting ~2.25" to 2.5" in front - from Stage3Motorsports forum sponsor
Rim/Tire: Weld wheel Ledge 6, 20x9, +20mm on 275/65R-20 116H Pirelli Scorpion All-Terrain Plus - from Discount Tire forum sponsor
