Tronald
Hello, I just received my 2023 PB with bed scales. When using "scale mode" from the 12" screen, changes in weight cause the weight readings on the scale to move side-to-side. It seems like a bug, and that the scale readings should move up/ down (revealing higher or lower numbers). Also dosnt actually tare to zero. It just causes the numerical scale to re-center within the "visible" window. So scale mode is unusable.
Has anyone else seen this? Tried searching but didn't see this specific behavior reported. Seems like a programming bug (change in X position instead of change in Y position).
If my description isn't clear, I can post a pic.
