Lariatom
- Tom
- Dec 7, 2022
- 0
- 21
- 3
- Rhode Island
- 2023 Ford F-150 Lariat
- Occupation
- Retired
Thanks much!
Thanks much.You have a few updates available
Hello Fordphanatic,No not available in fdrs
It looks like you and I are in the same boat where our hands free maps expired 10-12-2022. There are a number of other individuals in the same position, see BlueCruise Not Allowing Hands Free.Hello Fordphanatic,
I am having the same issue with my bluecruise maps not being updated. Any chance you can generate a list of updates my system needs? That way, I can clue off my shop as I have been in twice for 16+ hours of "service" without resolution.
My Vin is 1FTFW1ED9NFC18193
FOMOCO will not pay the dealer for the time to just update the truck unless you have a "CONCERN" that an update will correct under warranty.Thanks much.
Do you or anyone know the policy on providing updates at the dealer?
Are they obligated or is it a good will thing?
Does FOMOCO reimburse dealers for it?
Damn you got a lotHowdy, after spending about 2.5 hours with various Ford techs on the phone I'm still not seeing a promised OTA update. Could someone please take a look and post the OTA history for 1FTFW1EDXMFB04914
I'd be much obliged. Looks like I'm going to pull the trigger on a mongoose soon as the dealer is about 6 weeks out from being able to look at it themselves. Thanks so much for your assistance, I really appreciate it.
Yeah, RonaldFreeman was kind enough to pull that info for me a couple of days ago, and point me in the right direction for learning about FDRS/Mongoose options. Now I'm trying to learn a bit about the OTA updates that may or may not have been sent my way. If the dealer has to force them along with this list, does anyone know if they charge for their time? I forgot to ask when I booked an appointment for the end of Feb.Damn you got a lot
I can't see OTA history. You will need someone with access to PTS to see that.
No OTA history in the past 60 days. Sync version is relatively new, so I see no indication your truck is stuck not getting OTA's, you just haven't gotten any recently.Howdy, after spending about 2.5 hours with various Ford techs on the phone I'm still not seeing a promised OTA update. Could someone please take a look and post the OTA history for 1FTFW1EDXMFB04914
I can only see 60 days back into your OTA history. Based on the version of Sync you are, it looks like you got most of the older updates, but I cannot confirm for sure. I see you got 3.5.2 on 10/26. You were also sent a TRM update on 10/23, but that one failed. Error code reads as follows:I appreciate the help
1 FTFW1 ED1 MFC71467
You literally have 2.8.1 sitting in your queue right now. The OTA trigger was created less than two hours ago. Get your truck hooked up to a 10amp battery charger, check for updates on your touch screen, and initiate it. You truck will have to be parked and locked for about two hours while it updates. You can watch the progress bar on your touch screen as it installs. Avoid unlocking the truck or doing anything while it is installing. Good luck!Coming from this thread where I have No Blue Cruise but OTA Updates Work.
I wanted to see if I get some insight into both OTA updates and module updates. I have had the truck at the dealer once who did do a couple of recalls. But I never mentioned Blue Cruise to them. I totally forgot on the first oil change. Will bring it up this next one that's due in another month or two.
My OTA updates seems to be working fine and it just did one a day or two ago.
VIN: (deleted per member request)
