astrand1
Rugedraw, if you would be so kind to check mine thru PTS please and thank you!
1FTFW1ED1NFA79273
1FTFW1ED1NFA79273
No action since you got 4.2.2 back on 4/13, but your FDRS history shows you updated your GWM and TCU on 4/15, so you won't get 4.2.3 or 4.2.4 sent to you and if you do, it will fail since you already have the newer software. Your truck should have the same IPC and DSP updates available on it as mine does, which is why I wanted mine checked. The IPC update is the equivalent to 4.3.2.Rugedraw, if you would be so kind to check mine thru PTS please and thank you!
1FTFW1ED1NFA79273
copy. I swapped in the 12' digital cluster so IPC wise who knows if that makes a difference.No action since you got 4.2.2 back on 4/13, but your FDRS history shows you updated your GWM and TCU on 4/15, so you won't get 4.2.3 or 4.2.4 sent to you and if you do, it will fail since you already have the newer software. Your truck should have the same IPC and DSP updates available on it as mine does, which is why I wanted mine checked. The IPC update is the equivalent to 4.3.2.
Edit: Yours is a 2022, so maybe no IPC update in your case.
Thanks....you are all good in FDRS.
No OTA history in the past 60 days and your Sync version appears blank in PTS. I see your GWM and TCU was manually updated with FDRS (I assume by your dealer) 2 weeks ago, but nothing has been sent to your truck OTA yet,Can someone check if I have any updates pending? Thanks
1FTEW1C87MFB35071
See attached.Can I get the detailed service history on my truck from Oasis?
FordPass shows more dealer history than what was on my Carfax and the very short Oasis sheet from selling dealer. I think they just didn't print pages with old owner name or something.
I don't expect anything crazy, but got me curious.
1FTEW1EP1MFB72606
Ford skipped over a bunch of updates when they sent you 3.5.2 last month. You are missing 2.6.0-2.8.3 which is a significant amount of updates. There is only one way to get what you are missing now and that is with a Mongoose tool and help from the forum. If you want to get your truck updated correctly, lmk when you have a Mongoose and I will direct you to the right person. If you don't want to spend the money to get one, look up the threads I've started and get on the list on my Community Mongoose Thread to borrow one of mine.I just received update 3.5.4 for my 21 SCREW 5.0. Perhaps someone could please check and advise me of where I am overall with updates. I'm not smart enough to know if it's OTA or FDRS or both that need to be checked.
VIN 1FTFW1E50MFB76262
SYNC 4 Version 22293_Product revision 610
Thanks
1FTEW1C87MFB35071
Thanks
