FirstFord
- Jeff
- May 14, 2022
- 54
- 586
- 478
- South Central Missouri
- 2022 F-150 Lariat SuperCab 502A, 4x4 3.5 EcoBoost
2022 (took delivery March '22) Lariat 3.5 EcoBoost; 15,800 miles:
My truck is not a daily driver; typically, I drive it mainly just when I need a truck. That means that sometimes it actually is a daily driver, and other times it will just sit for days, or even weeks being parked. VERY early in the ownership experience (I think the second week...), I fell victim to systems shutting down to save the battery. It was, in fact, these experiences that sent me to F-150 forums (which is highly unusual for me!) before I made an appointment with the dealership. After looking through several different 14th Gen F-150 forums, I settled on this one. For one thing, it struck me as being more organized than the other forums. And my education commenced!
For almost 2 years, I have been regularly plugging my truck into a battery smart charger/tender, and it has solved the few issues I was having. But after almost 2 years of using the charger, my attitude towards this "solution" began to change. The whole process began to slowly become objectionable - I want to be able to just get in the truck and go! - and just like I do with every other vehicle. I found myself slowly begin to resent the fact that I had to plug my truck in every time I brought it home, and unplug it when I was going to take it out. Enter the H8 battery upgrade. I just swapped out batteries yesterday. These are my observations:
- As is my usual practice, I "topped off" the new H8 battery with a charger prior to installation. And I'm glad I did - when I put my charger on it, it reported that the new, off-the-shelf battery had a SOC of 64%. For the task of "topping it off", I purposely selected the 2A charger option to slowly bring it up to "full".
- In other posts, some people have reported experiencing difficulty in installing the battery, particularly with fit, and had to cut/modify the battery tray to get the H8 to go in. I had none of those experiences - the battery pretty much jumped right in!
- Prior to battery installation, I ordered the battery wrap "blanket" from an online Ford parts source, using the Ford P/N listed in many posts. The original battery blanket fit the battery very nicely. The new H8 blanket fit my new H8 really, really, tight - in fact, for awhile I thought I had the wrong blanket. I had to pull and stretch the blanket to finally get it on the battery. The stretching process reduced the thickness of the blanket significantly, and therefore (presumably) the performance of its intended purpose was reduced. I did not physically measure, but my eyeball micrometer indicated that the thickness was reduced by some 50%.
- The battery cables (and the cabling to aftermarket accessories attached to the "+" side of the battery) took a little "finagling" to get them to make the stretch to accommodate the longer battery, but not a major obstacle.
- I tested the old, original battery after I pulled it - it was at 78% SOC, supporting the statements made that Ford uses an 80% figure. After I pulled the old battery, I put it on a charger to "top it off" before it finds a second life in another vehicle.
- I performed a BMS reset. I hooked up the smart charger one last time for the overnight hours. According to my plans, that will be the last time
it goes on a charger.
- From here on out, I should (in theory, at least) be able to treat my truck like any other "normal" vehicle. We'll see how it goes.
