Remote start question.
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
I have an stx only have remote start through fordpass app. I see people with lower trims put the start x on their truck and like it. My question is this... when I use fordpass app to start it seems to go by temp as to using heat or ac. The start x said something about it using last set upon departure of vehicle.
That being said you guys with factory remote start does yours do the temp to select or last setting when you use key fob to remote start.
Lricaud81
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
The only remote start I saw thats factory add on has a separate key fob. I don't want that but would like the auto climate.
JohngaltinOC
Scott
Mar 11, 2021
211
145
Orange County ca
2021 F150 lariat EB
Finance
I have a 502a prior to all the "deletes", and from my recollection there was some setting where it uses either a preset temp or where we have it set when we exit..
Lricaud81
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
Yeah mine seems to be that when I use the app to start it bit when I heard of the start x on here somewhere I looked it up and I saw it says it uses the last set .. Unless I misread it.
Zyvin
697
914
SC
2021 F150 Crew, FX4, Lariat
Factory system can be set to auto (sets to 72 degrees), or you can set it to “last setting”. **note: once you get in and turn on the ignition it reverts to last setting.
You can also turn on/off the seats and steering wheel to come on with remote start.
Lricaud81
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
I'm pretty sure I have mine set to auto . If I remember right I saw that setting when i first set things up. Not 100% sure tho as I have an stx.
My understanding is if I went start x route and start it from fob with lock unlock lock or other way around. Lol. It'll just do the last used.
If anyone has start x and could chime in would be great.
I'd rather all oem but only see where you get a small fob with the start button on it and I don't want anything extra just use factory fob
fordtruckman2003
Apr 28, 2023
3,208
2,539
Indy
2021 F-150 FX4 Lariat
Check your sync settings screen for remote start options. Pretty sure that is there even if you don't have a remote start fob.
I understand the annoyance with app only remote start. My mom has that too with her Ecosport. I think it is a bit silly to have only the app but that is Ford being Ford.
All fob remote start on F-150 I believe even the lowest trim with it you could order required the push button in cab.
Lricaud81
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
Yeah im pretty sure I've seen that remote start options and put it on auto and when I started via app it was like that.
Lricaud81
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
start x goes off of last setting prior to shut off.
Do you happen to have start x or know someone that does.
I'm pretty sure I read that it goes by last set too
gagliano7
Joe
Mar 2, 2023
150
76
Monroe NY
2023 F150 4x4 XL STX BAP 5.0 3:73
I am pretty sure my starter x uses auto. My rear defogger is always on after a remote start and I also never use the rear defogger. I also notice the fan speed is high and when turn vehicle on the speed goes to usual low speed setting.
Lricaud81
Lricaud81
Jun 20, 2023
44
571
212
Louisiana
2023 f150 stx fx4
Only reason I really ask is because living in Louisiana this evening it will be 70° then in the morning it'll be 33° lol.
TruckBubba
John
Jun 6, 2023
Norther Virginia
2020 Mustang 2023 F150
Maintenance Specialist
I have remote start on my 2023 XL by way of FordPass and it starts with heat, which I like. Never tried in hot weather so I don't know about starting with A/C(?).
Graygoose2021
Nov 18, 2021
31
1,921
1,841
Central US!
Sales
The Start X should go off old settings when you turn truck off.
