AutonomousHybridF150
- Kristopher
- Jul 13, 2021
- 0
- 366
- 380
- Pensacola Fl
- 2021 F150 Powerboost
- Adjuster
On top of everything else I have ranted about, clearly the prior posters do not fully understand sample size and the scientific method.
We do not have nearly enough data from the video review to make any conclusions about how anything does or doesn’t work well in curves or with blue cruise either.
We saw maybe 3-4 curves in the video so that’s not even close to a resonable sample size.
2 things you should know about lane centering. It can’t navigate roads (lanes with lines) that get excessively narrow (similar to that curve) and it also thinks something is wrong when it sees solid white lines on both sides. It isn’t typical on roads, so it does confuse it sometimes. Also, there was a huge open area with no lines to the right and an 18 wheeler in the camera views to the forward right. It didn’t turn off ONLY because of the curve, it disabled lane centering ALSO because it wasn’t confident the 18 wheeler wasn’t a wall and there were no clear road edge lines, or dirt/grass, basically nothing for it to see. So that is an entirely different issue.
My lane centering can navigate curves with ease, and it does it even better when you have the aggressiveness on HIGH. When angular momentum is being changed it takes steering force to overcome the straight line that physics requires the truck to drive.
If the system fought you too hard, people would complain too, so there are 3 setting levels. If it isn’t aggressive enough for your liking, please turn it on high.
Not to mention Sandy Turned it off for one curve because he had no clue what he was doing not how the system works (lane centering without blue cruise).
Curve with solid lines:
Similar Angle / Sharp Curve (and Blue Cruise stayed on): In fact it looks like a steeper curve than the previous.
