Rear axle bolt failure...AGAIN!!
FDHog
Apr 10, 2023
84
111
NJ
2023 Lariat FX4 2022 Bronco Badlands
Retired FDNY
But wouldn't that mean it's NOT a batch issue and we should see equal percentage of bolt failures for every model year and build date?
That's what I would think. Seems like there aren't many reports if any of 23's failing. I'll just keep an ear out for bolt rattle. Easy enough to pop the center caps off.
Dfc41889
Dale
Jan 20, 2022
102
118
Huntsville, AL
20 Sierra AT4 HD (Trade) - 22 F150 Plat (Ordered)
Senior Financial Manager - CPA
19k miles and 700 miles from home and I hear rattling…..and it’s Memorial Day Weekend!
Ford F-150 Rear axle bolt failure...AGAIN!! 70682700073__ABC058DF-E5BD-4403-8192-26723EDC9461
9,040
16,381
I'm just putting myself in your shoes when I say this....
First, you can clearly see that shoulder that huge washer was seated on. So you can also tell with the naked eye IF it appears the axle has moved inboard or outboard since the bolt broke.
That's what I would monitor. But I would NOT let it influence my vacation unless I witness the splined shaft move considerably inboard/outboard.
Dfc41889
Dale
Jan 20, 2022
102
118
Huntsville, AL
Appreciate that but my vacation is over. Was going to drive home tomorrow but will be stopping at local Ford garage and figuring out a new way home. Ford already offered to ship the truck home after the fix and reimburse a rental car, so it will work out. Very frustrating though.
9,040
16,381
That's my point though. I'm no expert, but my understanding is that there's little chance of the truck being un-drivable. Certainly the wheels won't come off.
The only thing I can envision is the axle moving inboard enough to throw gear alignment off, but I thought there was a lock ring on that end prevent that.
Moving outboard would be wild to see in your rear view mirror? The splines sticking out of the wheel?
I'm just suggesting that you could avoid the shipping the truck fiasco.
But I totally respect anyone's decision not to.
74
4,542
4,670
2022 302a PB, Mach E GTPE
I'd only expect axle movement to be likely when it's completely unloaded and in a turn. Given that a lot of folks didn't know about the issue at all and basically tumbled the bolt into a different shape entirely means it'd gone over 1k miles of short range driving. There's only been one instance I saw where the axle slid in too much to the point of no longer engaging the wheel hub splines. Something is keeping it in else there'd be nothing to actually put load on the bolt itself. When the bolt was screwed in it'd still be able to be pulled out. Personally I'd drive it home and just not take wild left turns (if it's the driver side), vice versa if passenger.
WhiteLightningnshitshadow
Feb 24, 2023
46
559
327
Lead Engineer
Haven't we seen at least one or two 2023s pop up? Im sticking to thinking this is a consistent design issue.
9,040
16,381
There's literally 100's of thousands of them. If it was a design failure, therefore all trucks are equally vulnerable, the numbers would be substantially different, don't you think?
I mean you could be right, but statistically there are legitimate bookends to the build dates for the vast majority of those documented.
And if it is equally likely for all trucks with the floating axle, then statistically it's an even smaller likelihood for any single truck to be affected.
It seems very similar to the leaking exhaust heat exchanger on the Powerboost.
Popped up out of nowhere. Got a ton of press as the rash of leaks got reported. Then it slowed down considerably. Matching up with the classic batch scenario.
JJSnell
JJSnell
Feb 22, 2023
62
1,307
1,544
CdA, ID
2022 F150 Platinum FX4 PB
You could always take your truck to Wendle Ford in Spokane...
Being the proactive guy I am, I bought brand new bolts (Ford OEM unopened) and took them into Ford and asked them to replace the bolts...
They lost the bolts, couldn't find them anywhere.
(In my best Ron White voice), "They... Lost... The... F*****in... Bolts..."
Two months later, still waiting on replacements or them to cut me a check.
Wendle Ford, Spokane, WA
SumGuy
Jul 21, 2021
483
382
USA
F150 (perpetually on order)
Drugs
I can't get anyone at the dealer to tell me what the problem fix is. When the bolt fails then they replace the axle and the bolt but I don't know if the fix is to replace the bolt with a higher strength fastener or due to material capability they have to replace the axle as well when using a different fastener. The design team, materials group or the analysts should have caught this!!!
I’m guessing the engineering team DID know and spec’d the correct type of bolt.
then the value engineering team came over top and said to use a cheaper bolt.
JacobH
Jacob Herrmann
Jun 1, 2022
39
Indiana
2021 F150 King Ranch Powerboost
Project Engineer
I’m wondering if my leaking rear passenger axle is part of this problem. I seem to have an oil type substance leaking from my wheel and covering both it and my tire and my wheel well. It’s not like a massive amount but it does seem like a good bit 😬. I’m going to pop the cover off on my lunch break and see if the bolt is fine and see if that’s where the leak is but I have it set up to go in on the 21st as I had to schedule out a little ways to get hail damage repaired. Last year in October I had both my rear axle shafts replaced due to BOTH bolts being broken 8+ hours from home. Tbh I drove all the way home and even continued to drive for a week or more before I got it into the dealer and it drove fine. At the time I was talking on another thread about it and a bunch of people told me they were still driving on a broken bolt lmao. I haven’t heard the rattling since so hopefully I’m still good🤞.
Gros Ventre
Nov 13, 2021
1,649
1,131
Western Wyoming
Powerboost
Go look at the bolt spec. This is sounding like a brittle failure. It could be that Ford specified a bolt hardness higher than really needed. (Note: as hardness increases brittleness increases & ductility decreases) Similarly Ford might have received a batch of bolts that are harder/brittler (eg less ductile) than needed or spec'ed. Once that batch exhausts and bolts with a less brittle nature populate their shelvs it'll go away. For your way forward, see if you can get the bolt spec and go buy one meeting that spec independently and have it installed. (Note: so long as it meets the Ford spec the warranty will not be violated.)
JacobH
Jacob Herrmann
Jun 1, 2022
39
Indiana
Project Engineer
I just popped the cap on my leaking rear axle to see mine is infact broken again. Second time, I had both sides replaced in October so hopefully it will still be covered under warranty.
Ford F-150 Rear axle bolt failure...AGAIN!! IMG_5247
Ford F-150 Rear axle bolt failure...AGAIN!! IMG_5248
Ford F-150 Rear axle bolt failure...AGAIN!! IMG_5250
Ford F-150 Rear axle bolt failure...AGAIN!! IMG_5251
Gros Ventre
Nov 13, 2021
1,649
1,131
Western Wyoming
Powerboost
That's a 10.9 bolt. That's pretty hard. Check that that's what Ford specified first. Then see if you can get one independently from Ford and have it installed (this to sidestep the "bad batch" syndrome). Most NAPA stores carry such bolts. You may find that Ford specified something like a 10.8 bolt which would have a bit more ductility (less likely to crack).
74
4,542
4,670
The fact it's leaking in ~8 months means those ass hats either damaged or didn't replace seals. I hate dealers. You should have a 12 month warranty on any work and parts.
