Csvt18
Mar 25, 2022
160
64
SE Michigan
2019 f150 SCEW (current), 2022 f150 (ordered)
Curious as I have a screw 5.5 bed, 5.0, max tow coming. I ordered a 2.5” spacer. My 2019 157” screw max tow had the 2.5” level and it still had just over 1” of rake and towed great no sag with a wd hitch and 7,000 lbs.
780
Todd
Feb 2, 2022
1,294
1,076
edmonton
I think you definately would be. Part of what I hoped would come out of this thread is understanding if those who do a 2.0 or 2.5 level....do they get nose high with a moderate load and it isn't a big deal, or do they not really ever get anywhere near 1000+ pounds of cargo & tongue weight? I have 1.5 leveling spacers that I bought for my 2020 and never installed. If I go bigger on tires once the OEMs wear out I may install them, but if I do the blocks are going back in the rear so my rake stays around 2".
Exactly. Just my tongue weight is 565 lbs. Then add in a couple rows of firewood... If I could get my onbard scales and SmartHitch to function properly, I'd know exactly how much weight we're usually travelling with.
Like you I want to go up a size or so when the factory rubber wears out. So was thinking a 2" level. Just don't know...
780
Todd
Feb 2, 2022
1,294
1,076
edmonton
502a, Crew cab, 157, Max tow, fx4
All measured empty.
Good to know as I have a 157" with FX4 and Max Tow as well.
Do you plan on hauling or towing with it?
I also have the tail gate step. Wondering if that added weight all the way at the back of the truck could affect rear measurements....
Badhabit
Dan
Nov 11, 2021
118
135
Missouri
2018 F150 SCrew 4x4 5.0 302A
Based on my results, and measurements from others with max tow, you should end up with 1" - 1.25" of rake.
Csvt18
Mar 25, 2022
160
64
SE Michigan
With the 2.5” level correct?
GIjoe
Joe
May 20, 2022
327
224
Ohio
2013 f250
302a fx4, no tow packages, 36g tank. Just over 40” front, 41.75” rear. 21-22 fox 2.0 with 275/65/20. My memory says I got 2” lift upfront but I’m starting to think it’s closer to 1.5-1.75 looking at it.
Ford F-150 Rake, Sag, Hauling, Leveling, Towing, Lowering Measurements 4E7A4632-AED5-4317-95D6-01F15712C251
Ford F-150 Rake, Sag, Hauling, Leveling, Towing, Lowering Measurements 858CCCB1-186A-4A30-B8CD-A627A41CDD5C
Zengineer
Zengineer
Jun 2, 2022
592
866
Midwest
2022 Lariat 157wb
I’m glad you mentioned this. Trucks with essentially all the forward rake removed tend to appear visually nose high, even if the tape measure says otherwise.
Having the rear wheel liners goes a long way towards making the rake look less visually jarring...especially on lighter paint colors. For my last 3 trucks...2012, 2020 and 2022...about 2" rake is the sweet spot for me. It quiets the look down from the 3.5" factory rake but allows loading almost to the payload limit without going too far into nose high territory. with 1200 lbs I get right around 2" sag and at about that point the Max Tow springs are fully engaged and more load doesn't move it much.
Zengineer
Zengineer
Jun 2, 2022
592
866
Midwest
2022 Lariat 157wb
Don't tell the BAP pack...but that Sport Package looks much better than the Black Appearance Package on a black truck.
F150SWPlat
Aleksandr
Sep 24, 2021
124
124
Tri-State Area
F150 Platinum 2021-2022
IT
I’m glad you started this thread.
I hope more people contribute and please include all suspension changes.
At the moment, I want to do a 2.5 in front, but I want to pair it with a block that will raise the rear 3/4” and the Roadmaster HD setup. I will likely still have a “noticeable” rake, butI doubt it will be near stock rake and I will be surprised if I experience severe squat unless I drop the 1400 lbs of remaining payload I have on the hitch.
I agree don’t level, raise front and compensate by adding a decent size block in the back.
i leveled my Superduty with a 2.5 inch carli kit and boy did it look like one ugly fucker being perfect level. I added back a 2” rear block and it looks tall and good again with some mild rake. It looks like a truck again.
Now whenever i see a perecty leveled truck it makes me uneasy. Will never make the same mistake again. Trucks are not meant to ride leveled.
TXBJJ
Steve
Feb 6, 2022
34
2022 F150 3.5 ecoboost XLT Sport Max Tow FX4
Removed my rear blocks the other day after reading this thread and another about rear block removal.
Stats
Stock fx4 max tow SCrew 145
3 3/4 rake, settled to 3 1/2 after hauling stuff around/10k miles
Block removed
2 1/4 rake
Very satisfied with the improvement in look and that this was a free and reversible mod although I did buy the (not cheap) 2WD u bolts.
Will see how things turn out when I hook up a TT. I'm looking for one in the 4-6k lb range so I'm thinking I will be ok.
Ford F-150 Rake, Sag, Hauling, Leveling, Towing, Lowering Measurements 20221023_184016
Aero
Nov 7, 2022
AL
'22 F150 XLT, FX4, BAP
Really appreciate this thread. Thought I'd contribute my own specs, findings, and questions.
Truck Specs:
2022 XLT SuperCrew, 302a, 3.5L EB, 3.31 axle ratio, 7050# GVWR
Packages: Trailer Tow (NOT Max Tow), FX4, BAP, Bed Utility
Currently about 360 miles on the odometer.
Here are height measurements (no load, no occupants, ~1/4 full tank)
Ford F-150 Rake, Sag, Hauling, Leveling, Towing, Lowering Measurements 1668708911645
Ford F-150 Rake, Sag, Hauling, Leveling, Towing, Lowering Measurements 1668711141949
Seems odd that the rear height is 1/2" higher on the passenger side... think the driver side rear tire pressure may be a little on the low side. I swear I'm not THAT overweight! :LOL:
I don't mind a little bit of rake, but I'm wanting that tail end to come back to Earth a bit. I'm just uncertain how much I should drop it. Debating on just removing blocks, adding drop shackles, or maybe both? My primary use is simply a daily driver with occasional use as a haul and tow vehicle. We want to get a camper in the near future, so this truck will be towing whatever we get - probably something in the 5,000lb range. I suspect I will never have a need/desire to bring it near capacity.
I feel capable to do the work myself, but am lacking in the tools department. So I may need to look at having a shop do the work if the tool cost just doesn't make sense.
Any thoughts/comments are welcome.
trabo
Jul 17, 2022
93
67
SoCal
2023 Powerboost, 2016 Highlander
Titanium and Plastic
Truck Specs:
Reviving an old thread here. What did you end up deciding?
