EricR
- #46
Great, awesome and nice work!I have also configured my 2021 PowerBoost with 7.2 kw ProPower Onboard to provide full electrical power to an Airstream trailer while in motion. This from my post on the Airstream forum.
Now on the home stretch of this Electric GlobeTrotter conversion. For the last few weeks I have been researching the feasibility of towing the GT with full 7.2kw electricity available to the trailer. The main concern I had was maintaining a water proof connection from the F-150 inverter back to the trailer. Since the only access to the 110 volt system was via the 50 amp connector on the aft driver's side of the trailer it was clear a second connection was needed to feed the F-150 ProPower output to the Victron MultiPlus in the trailer.
My solution was to run a 4 wire, 30 amp cable from the front hitch back to a Progressive Dynamics PD52V Transfer Switch near the 50 amp plug input.
At the hitch the 30 amp cable joined with the 7 pin connector then over to connect with the truck. The F-150 ProPower Panel is on the driver's side aft bed wall which is not a convenient place to hook up the 30 amp cable while under power. I found an existing hole in the bed that was larger than the 30 amp cable so I was able pass the cable down the bed support behind the rear bumper.
To make the connection between the trailer and the truck I sourced waterproof NEMA L14-30 connectors (Molex Woodhead 28W74 and 29W74. These connectors are not easy to find.
Here is how it looks with all three cables from the trailer plugged into the F-150 PowerBoost. Ran some tests cycling through AC sources in the trailer and all seems to work. The 30 amp cable is about the same diameter as the 7 pin cable. I have some extra cable coiled up on the hitch so that I can park the F-150 away from the trailer while camping but still maintain a connection to the truck.
This is what I was hoping to see when I started this thread!
-EricR
