McTremor22
I’ve been reading through forums and have still yet to find an answer I’m comfortable with. Hoping for a little help….
After reading I decided to order the pro comp 2.5 level kit for my 2022 tremor. After reading more I ended up ordering the auto spring 2.5 level as well.
So now I need to figure out which one I want installed. From what I’ve seen the pro comp level is better for the cv angles but stiffening up the ride because of the pre load spacers. Where as the auto spring seems to not change the ride quality but does have more extreme cv angles. I’ve also noticed with the auto spring level the results are all over the place as to where the rake ends up. I want some rake if I load the bed. Don’t do much towing. Right now my truck has 16k and sits right at 4” of rake.
I’ve also seen mixed results on the rear block size. Some say it has to do with whether or not you have the towing package option or not as to what size the rear block is. Possibly thinking that could be why I’m seeing extreme differences in the end results on people level
if anyone has a suggestion on the best kit to use I’d appreciate it greatly. Also any confirmation on the rear block size theory. Thanks for the help!
