Powerboost whistle?
CardsFan
Tim
May 13, 2021
30
Kentucky
2021 F150 XLT SuperCrew
Hi All,
I have had my Powerboost for a few months now (5,500 miles) and really loving everything about it. One thing that I am trying to determine is if this high pitched whistle sound I am hearing is normal. I know the backup beep. I also know the safety hum that is there until 18 or so MPH. However, I also have this whistling sound during acceleration up to 60 MPH or so. This is the first time I have had turbo boosters, so was thinking that could be it, but it also seems to happen when I am on full electric. It is one that the pitch gets higher as the RPMs increase and then goes away/reduces as it shifts gears. It would be good to hear if anyone else hears this or not so I can determine if it's something that's normal or should take in.
Thanks.
Tosh
Apr 2, 2021
229
195
Willamette Valley, Oregon
2007 Jeep WK CRD, 2021 F150 Lariat PB
Re-Tired Bicycle Mechanic
What I can hear from my truck is not what I would call a "whistle", but I would call it a whine". I can hear the electric machine (motor/generator) in operation. More when it's in generator mode and less when it's in motor mode.
I hear the same noise from my neighbor's Lexus RX470, and also from the Prius my buddy drives.
Jerry Can
Jan 22, 2021
148
168
Calgary
2021 F150 KR Powerboost, 2-tone Rapid Red, 157”
Fuel Container
Hi All,
Thanks.
That’s turbo whistle, it’s normal, and I hear it on my truck. It‘s from the compressor side of the turbo, and can be heard from the air intake when the throttle body is wide open and the turbos spooled up (i.e. under moderate to hard acceleration).
imnuts
Mar 1, 2021
1,270
1,315
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Turn on the boost gauge if you have that option and watch boost just to verify that it is the turbo spooling up.
Jrohner78
James
Apr 12, 2021
42
Iowa
2021 xlt fx4
This is my 3rd Ecoboost engine but my first powerboost obviously. I at times do hear a whine while under moderate to hard acceleration that is not the turbos. I've chalked it up to the hybrid drive for now but I'm keeping my ears on it to see if it ever changes.
CardsFan
Tim
May 13, 2021
30
Kentucky
Thanks everyone. I will for now just chalk it up to normal. Not sure if it is audible from outside the vehicle, but definitely inside I hear it. I will see if I can keep it in the same mode I am in but change the display so that it shows the booster to see if it is spooling up when I hear the sound.
Thanks,
Tim
Jerry Can
Jan 22, 2021
148
168
Calgary
Fuel Container
Perhaps it’s something other than turbo whistle then, because that noise is a “swooosh” sounding whistle that comes from the engine bay and will be louder outside the vehicle. When checking to see if the noise corresponds to boost pressure, also check if it’s louder with your window open.
David Gordon
Sep 17, 2021
39
76048
2021 F-150 Platinum Powerboost
Oilfield
I dont know what it is but is sure as hell annoying, I assume it is the electric motor or generator.
Almost as annoying as the backup beeping.
CardsFan
Tim
May 13, 2021
30
Kentucky
Yes, you have the ability to customize the 2 center gauges. With your vehicle on, you can go to:
  1. Hit the Menu button on your steering wheel
  2. Scroll to Settings and press OK
  3. Scroll to Configure Gauges and press OK
  4. You can choose Left or Right Selectable Gauge
  5. Scroll to the boost selection and click OK.
I haven't had a chance yet to see if the boost is kicking in when I hear the whistle, but will do that sometime today and report back.
Clsam
Nov 7, 2021
2021 F150 Powerboost
Hi All,
Thanks.
Any luck nailing down what this may be? Just got my ‘21 Powerboost, and around hitting a couple of hundred miles mine started making a noise just like you have described. I’m almost certain it wasn’t making the noise when I first brought it home.
Clsam
Nov 7, 2021
It's definitely inconsistent - didn't make the noise on my way to work this morning, noise was back as I drove home for lunch. Real high pitched, gets higher pitched as I accelerate & gears shift up, lower pitched as I let off the gas.
The Rod
Max
Nov 8, 2021
Maryland
F150 Powerboost
Hi All,
Thanks.
I know exactly what you mean. It sounds almost like a vacuum leak. It is NOT the turbo. I had mine in the shop a few weeks ago and they couldn't figure out what it was. Mostly hear it when I'm in electric as well.
Bandito
Rodrigo
Oct 19, 2021
42
30
Chicago, IL USA
2021 Ford F-150 Limited PowerBoost
The electronics, in particular the high-voltage components, do make noise. I could easily hear them in my Toyota Highlander, but I don't hear a similar high-pitched whine from my PowerBoost.
At any rate, you could just be lucky enough to have good hearing in the high-frequency range that allows you to hear more of this type of noise. Just a thought.
ConiferEric
Eric
Oct 29, 2021
34
Conifer, CO
2021 Ford F150 Lariat, Powerboost Hybrid
Well, the same whooshing noise started for me at about 900 miles. I can hear it anytime I'm traveling above 45MPH. I've rolled the windows down so I could hear the noise better and I actually think the noise goes away. With the windows up it sounds like its coming from the passenger side front of the vehicle. This is my second ecoboost F150, its definitely not the turbo's spooling up.
