Jmitchelltfo
I might be the only person to ever have this issue but here goes. I went to do a drain and refill on my transmission, only to find that a dealer or the previous owner had rounded the aluminum cap for the dipstick. It came off, but the crows foot flare wrench had to be modified to swing around farther on the nut since the heat shield makes clearance a little snug.
I didn’t want to put that piece of junk back on…… so I found a steel replacement. I just had to wrap a small rubber band around the top of the dip stick to help it hang on to the cap when it lifts up for a tighter friction fit.
https://a.co/d/iM5ceyd
