Oxford_Powerboost
- Austin
- Jul 16, 2021
- 3
- 831
- 1,076
- Northern Virginia
- 2023 F150 Lariat 5.0
I have not noticed this. When cold and always on auto, the fan continues to blow hot air full blast even after 5+ minutes with the engine off electric idlingProbably not the issue, but just throwing this out....
You need to have Climate Control in Auto, if you don't want the fans to blow constant, regardless of the temp of the air in the system.
If you have Fan on manual, then as the Temp of the Heater core is modulated (either from ICE hot coolant or the auxillary heater), it will blow warm then continued to blow getting to cooler until the set temp requires the heater core to start heating again.
On Auto, the fan will drop back to minimum when the heater core is no longer heating, waiting for the cabin temp to cross back over the set temp requested, then ramp up again when heater core starts applying heat.
Same for cooling with A/C.
