unixadm
- Feb 15, 2021
- 20
- 206
- 292
- Elk Grove, CA
- 2021 F150 Platinum PowerBoost FX4
The PowerBoost has a coolant pump dedicated to the HVAC system and also has an Electric Booster Heater.
Supplemental Climate Control - Overview
Overview (Diesel equipped)
An electric booster heater is available as optional equipment on diesel vehicles. The climate control system uses the electric booster heater, also known as the PTC heater, to heat the passenger compartment in place of the heater core in low ambient temperatures. Once engine coolant reaches a sufficient temperature and can maintain it to heat the passenger compartment, the climate control system stops using the electric booster heater.
Overview (Hybrid equipped)
The cabin coolant heater system provides warm coolant to the heater core to warm the passenger compartment whenever the front DATC module requests heat and the HEV is in a driving mode, remote started, or doing Cabin Drive Conditioning. The climate control system uses the cabin coolant heater to heat the passenger compartment in place of the heater core in low ambient temperatures. Once engine coolant reaches a sufficient temperature to heat the passenger compartment, the climate control system stops using the cabin coolant heater. The cabin coolant heater system consists of the following components:
- Cabin heater coolant pump
- Cabin coolant heater
- Cabin heater coolant diverter valve
- Heater core
- Cabin heater coolant temperature sensor
