Wow, FINALLY! Congrats on getting your truck back. Yours took much too long!Congrats to you both (@70Mach1 & @PeaksFord ) for movement on your trucks (even if a different one).
I drove mine home, parked it and opened the hood. The next morning - no leaks and coolant was at Max. That is a weird but happy feeling.
Got the steering column wiring harness recall done (wiring connector was replaced) and the Trailer software recall done as well. I did note the truck struggled to find a gear leaving the dealership (20-30 mph, 4th gear was in there somewhere), but it settled down after that and the ride home was smooth.
Good luck all and I hope no one breaks my record. @DB63 - we need yours fixed now!
The party finally came for my truck and it was replaced yesterday. The service center at my dealer says it sees what the issue is with engineering and is providing feedback to ford.Mine got repaired today, but I confirmed it too late to pick up the truck, so that will happen tomorrow.
Let me know of any mistakes. Thanks!
Name Blend Bed/ Part Told Dlr Miles Can Drive part ordered part arrived Install Date Issues After? Dan65 repair#1 12/22/215.5/W 1/20 166No 01/20/223/17/2022 56 days YES - ~5000 miles, in May leaking again Rhymeand reasons 01/05/225.5/W 2/16 1990No 02/18/223/9 - arrived damaged - re-ordered 3/9 - arrived 4/7 4/8/2022 51 days No!!! Nasto 01/05/226.5/V 2/22 296No Wrong -S part ordered: 2/23/22. Re-ordered -V: 03/09/22. 3/29/20223/30/2022 37 days no Cuse0307 repair#1 01/15/226.5/V 3/19 3300No 03/20/22 5/13/20225/13/2022 55 days YES - 900 miles and leaking again Bellin stoke 02/01/225.5/W 3/23 2600No -- -- 4/14/2022 22 days no Thunder chief 12/23/215.5/W 3/28 1237No 03/28/22 4/25/20224/26/2022 29 days no MTPower boost 12/06/215.5/W 4/8 3127No 04/06/225/11/2022 33 days No - 150 miles so far Matthyius 01/06/226.5/V 4/18 3930No 04/22/22scavenged off new truck in lot 6/20/2022 63 days No - 2000 km so far FORD offering 3 month payments 8yr/180k km warranty Deeds972 MY22 6.5/V 5/9 4800No 5/23/2022 14 days No Dan65 repair#2 12/22/215.5/W 6/9 5002No 06/09/22 7/25/20227/27/2022 48 days emiantan 12/20/225.5/W 6/16 6728No (but kept at home for mods) 06/17/22 7/27/20227/27/2022 41 days Oxford_Po werboost 09/27/215.5/W 2/7 7600Yes 02/07/22 5/20/20225/25/2022 107 days no Dmark john 12/20/215.5 W 2/21 400Yes 02/21/22 3/10/20223/11/2022 18 days No- have 4K miles post repair and everything is good iceman77 01/06/225.5/W 2/22 1707Yes 02/24/22 4/21/20224/23/2022 60 days no - ~5k miles so far with no leaks MrFarly repair#1 01/04/226.5/V 4/8 8000Yes 04/11/22 5/11/20225/12/2022 34 days YES - @ 2500 miles leaking again MrFarly repair#2 01/04/226.5/V 6/6 10900Yes Corporate Ford tech expedited and looked at this 2nd leak 6/14/20226/21/2022 15 days Sir Choppins 12/17/215.5/W 6/2 1200Yes 06/06/22 7/11/20227/12/2022 40 days Boone 2/1/20215.5/W Mar 2022 20550Yes 7/27/2022 ~4.5 months TN Rotty 12/19/216.5/V 3/1 1100Yes 03/07/22 7/21/20227/28/2022? 149 days -------- -------- -------- ----- ----- -------- -------- -------- -------- -------- DB63 12/14/215.5/W 3/14 1000Yes 03/14/22Ford Driver 01/22/225.5/W 3/29 300No 04/22/22RyanC111 04/21/216.5/V 4/7 7694Yes 05/25/22Zakloosle 12/17/216.5/V 4/26 2900No 4/26/22? Klvanzu 01/16/225.5/W 5/11 3100Yes 05/11/22Cuse0307 repair#2 01/15/226.5/V 6/6 4200Yes 06/06/22New V part leaking after 900 miles Puddle 01/09/225.5/W 6/202000 km No 6/23/22? 70mach1 12/16/215.5/W 6/22 4500No ?? PeaksFord MY22 5.5/W 6/28 4852No 07/07/22JLOYD98 03/15/215.5/W 7/19 13500No (CEL since 4/20) 7/22/2022
Original part# (dependent on bed size) ML3Z-5A212-S.
The updated part for a 5.5 foot bed is ML3Z-5A212-W.
The updated part for a 6.5 foot bed is ML3Z-5A212-V.
For any new records get me the info in a column like so :
Name
Blend (build date of your truck)
bed length/part letter
told dealer date
mileage when leak noticed
drivable y/n
part ordered date
part arrived date
installed date
any issues after
Example:
TN Rotty
12/19/22
6.5/V
03/01/22
1100
Yes
3/7/2022
If you have no info for a field, no worries - just put ??? or similar for that item
Nice of you that you declined the loaner if you didn't need it. If you can get me your stats for the tracker, I'll add your data.Good lord, I had no idea this was such a widespread issue.
I did not get any CEL related to engine coolant leak (though I did have one for autolamps not working which eventually fixed itself). However, I found there was a pretty good coolant leak when the engine bay fan turn on so loud and aggressively I thought the whole truck was about to take off. Dealer did an "emergency" order and we finally got it here 3 weeks later. Currently at around 20,000km on the truck. Dealership offered by a loaner or free bottles of Motorcraft engine coolant for hybrids. I declined in the loaner (we had a tornado rip through the southern part of the province so there's other people who need a loaner vehicle more than I do) and I'm on my second jug of coolant. Should be getting repaired Aug 11th. Fun times!
If by issue you mean the heat exchanger leak, that seems to be what is happening. My repair sheet did not state any other parts.To fix this issue on a 5.5 bed all they are replacing is ML3Z-5A212-W ?
Good news - that was 2 months on your latest wait. See if you can find what issue the service center found regarding engineering. (Could it be a plastic part bolted to the metal exhaust?.)The party finally came for my truck and it was replaced yesterday. The service center at my dealer says it sees what the issue is with engineering and is providing feedback to ford.
The Service Charging System warning magically went away and my dealer says it sees no issues with the battery or alternator so not sure what that was about.
Name | Blend | Bed/ Part | Told Dlr | Miles | Can Drive | part ordered | part arrived | Install Date | Issues After? |
Dan65 repair#1 | 12/22/21 | 5.5/W | 1/20 | 166 | No | 01/20/22 | 3/17/2022 56 days | YES - ~5000 miles, in May leaking again | |
Rhymeand reasons | 01/05/22 | 5.5/W | 2/16 | 1990 | No | 02/18/22 | 3/9 - arrived damaged - re-ordered 3/9 - arrived 4/7 | 4/8/2022 51 days | No!!! |
Nasto | 01/05/22 | 6.5/V | 2/22 | 296 | No | Wrong -S part ordered: 2/23/22. Re-ordered -V: 03/09/22. | 3/29/2022 | 3/30/2022 37 days | no |
Cuse0307 repair#1 | 01/15/22 | 6.5/V | 3/19 | 3300 | No | 03/20/22 | 5/13/2022 | 5/13/2022 55 days | YES - 900 miles and leaking again |
Bellin stoke | 02/01/22 | 5.5/W | 3/23 | 2600 | No | -- | -- | 4/14/2022 22 days | no |
Thunder chief | 12/23/21 | 5.5/W | 3/28 | 1237 | No | 03/28/22 | 4/25/2022 | 4/26/2022 29 days | no |
MTPower boost | 12/06/21 | 5.5/W | 4/8 | 3127 | No | 04/06/22 | 5/11/2022 33 days | No - 150 miles so far | |
Matthyius | 01/06/22 | 6.5/V | 4/18 | 3930 | No | 04/22/22 | scavenged off new truck in lot | 6/20/2022 63 days | No - 2000 km so far FORD offering 3 month payments 8yr/180k km warranty |
Deeds972 | MY22 | 6.5/V | 5/9 | 4800 | No | 5/23/2022 14 days | No | ||
Dan65 repair#2 | 12/22/21 | 5.5/W | 6/9 | 5002 | No | 06/09/22 | 7/25/2022 | 7/27/2022 48 days | |
emiantan | 12/20/22 | 5.5/W | 6/16 | 6728 | No (but kept at home for mods) | 06/17/22 | 7/27/2022 | 7/27/2022 41 days | |
Truck traded out to dealer | |||||||||
70mach1 | 12/16/21 | 5.5/W | 6/22 | 4500 | No | ?? | 7/29/2022 | 7/29/2022 37 days | |
Oxford_Po werboost | 09/27/21 | 5.5/W | 2/7 | 7600 | Yes | 02/07/22 | 5/20/2022 | 5/25/2022 107 days | no |
Dmark john | 12/20/21 | 5.5 W | 2/21 | 400 | Yes | 02/21/22 | 3/10/2022 | 3/11/2022 18 days | No- have 4K miles post repair and everything is good |
iceman77 | 01/06/22 | 5.5/W | 2/22 | 1707 | Yes | 02/24/22 | 4/21/2022 | 4/23/2022 60 days | no - ~5k miles so far with no leaks |
MrFarly repair#1 | 01/04/22 | 6.5/V | 4/8 | 8000 | Yes | 04/11/22 | 5/11/2022 | 5/12/2022 34 days | YES - @ 2500 miles leaking again |
MrFarly repair#2 | 01/04/22 | 6.5/V | 6/6 | 10900 | Yes | Corporate Ford tech expedited and looked at this 2nd leak | 6/14/2022 | 6/21/2022 15 days | |
Sir Choppins | 12/17/21 | 5.5/W | 6/2 | 1200 | Yes | 06/06/22 | 7/11/2022 | 7/12/2022 40 days | |
Boone | 2/1/2021 | 5.5/W | Mar 2022 | 20550 | Yes | 7/27/2022 ~4.5 months | |||
TN Rotty | 12/19/21 | 6.5/V | 3/1 | 1100 | Yes | 03/07/22 | 7/21/2022 | 7/28/2022? 149 days | 1 week and 250 miles - good so far |
Cuse0307 repair#2 | 01/15/22 | 6.5/V | 6/6 | 4200 | Yes | 06/06/22 | 8/6/2022 61 days | ||
DB63 | 12/14/21 | 5.5/W | 3/14 | 1000 | Yes | 03/14/22 | |||
Ford Driver | 01/22/22 | 5.5/W | 3/29 | 300 | No | 04/22/22 | |||
RyanC111 | 04/21/21 | 6.5/V | 4/7 | 7694 | Yes | 05/25/22 | |||
Zakloosle | 12/17/21 | 6.5/V | 4/26 | 2900 | No | 4/26/22? | |||
Klvanzu | 01/16/22 | 5.5/W | 5/11 | 3100 | Yes | 05/11/22 | |||
Puddle | 01/09/22 | 5.5/W | 6/20 | 2000 km | No | 6/23/22? | |||
JLOYD98 | 03/15/21 | 5.5/W | 7/19 | 13500 | No (CEL since 4/20) | 7/22/2022 |
10 days post-part replacement and all operating normal with no leaks or messages. As a side note I was working with Ford Corporate on the issue and as a token of goodwill they provided me with a 4 year 60K mile maintenance plan (starting now) for my inconvenience. Plan takes care of oil changes, tire rotations, brake pads , etc. and routine maintenance items. Appreciate it, albeit after a long and frustrating journey. I also have an ESP purchased when I bought the vehicle so that should keep me covered for a while. My dealer in Janesville, WI was helpful throughout the process as well, but working with Ford Corporate I believe at least gave me another path and offered an additional outlet for my frustrationFinally received my new exhaust pipe extension P/N ML3Z*5A212*W and the dealer installed it today. Fixed the P237C code I have had since March 2022. Never had any leaks, but did have the CEL and experienced reduced power while towing or in hot ambient temperatures. No issues so far and will continue to monitor. I did ask the dealer if I could have the old part to retain as a spare in case the new one starts leaking (old part never leaked, just had issues described above). They said they have to hold it for 45 days to see if Ford requests it under warranty otherwise I can have it. Figure it would be a good "spare" to have on long camping road trips, especially if the new one starts to leak or fails, at least I would have a known no-leak spare to get me home. So for me, it took about 4 1/2 months to get the part. So hope is on the horizon for all...
Made me wonder the same thing if the 12/20 week hold overs were leaking PB heat exchangers or other similar QC issues caught on the line and then waiting on parts.The blend dates make me real nervous about getting mine next week, mine was 12/27. It took them until now to ship it so maybe it leaked right off the line and they fixed it already? Crossing fingers..haha.
Glad to hear it's working and Ford worked with you on it. If you can get me your info, I'll list it on the tracker. Good luck!10 days post-part replacement and all operating normal with no leaks or messages. As a side note I was working with Ford Corporate on the issue and as a token of goodwill they provided me with a 4 year 60K mile maintenance plan (starting now) for my inconvenience. Plan takes care of oil changes, tire rotations, brake pads , etc. and routine maintenance items. Appreciate it, albeit after a long and frustrating journey. I also have an ESP purchased when I bought the vehicle so that should keep me covered for a while. My dealer in Janesville, WI was helpful throughout the process as well, but working with Ford Corporate I believe at least gave me another path and offered an additional outlet for my frustration
