blacklion6
After reviewing I do not. I got confused by the email I was sent almost a year ago. SMHdoes your truck have blue cruise ??
I got the same email from ford stating, “Your vehicle is already equipped with the necessary hardware for this feature.” Looks like I won’t be getting it after all. I didn’t initially expect it but now it is a let down.After reviewing I do not. I got confused by the email I was sent almost a year ago. SMH
Same. I wish they would have sent a follow-up email to limit confusion, especially since everything is Co-Pilot 360 "XXX." Like what marketing person came up with this crap?I got the same email from ford stating, “Your vehicle is already equipped with the necessary hardware for this feature.” Looks like I won’t be getting it after all. I didn’t initially expect it but now it is a let down.
This is interesting. Does the truck wifi+sync system need both hybrid battery and normal 12v battery charge for the OTA to function?Probably your battery strength. If you have a battery charger would suggest leaving it hooked up overnight.
Awesome thanks! so would it be one of these?I have the 12" screen in my 2021 Lariat, and it's under Settings, About Sync. If you go there, get that info and then head over to the Ford Sync 4 wiki page that lists all the versions and updates, you should be able to match up where you are on your truck.
No problem!Awesome thanks! so would it be one of these?
appreciate the help i'm lost with tech, give me a carburetor and i'll make 'er purr like a kitten!
thanks very informative! Yeah I think that makes a lot of sense.No problem!
Now, go to this website here and you can match up what you took a picture of there against the different update stages. https://en.wikipedia.org/wiki/Ford_Power-Up_Version_History
Edit: I don't see your version on that wiki called out specifically. But, I do find other threads of people that have your version and they hadn't had any updates yet. So, I suspect that your version actually maps to the very bottom row in that wiki which would be the initial version that came from the factory. All the updates listed on that wiki are sequentially higher than what you have. Given that you don't believe you've gotten an update yet, and all the updates listed are above your version, I think it's safe to say that you're on the initial version that came with your truck.
So I got 2.8.3 last night. No alert or notification, but when I checked the app, it says it installed 7/29. I just went out to the truck and can now can select multiple daysI noticed that I just got this "22-PU0614-SRV-RC" update about a week or so after I had gotten 2.8.2. I just checked and while it reset to default with no day or time selected in the scheduler, it also didn't fix the issue where I can only select one day in the scheduler versus all days. So an update to allow me to get better updates disabled the scheduler.
