They are Black Rhino Overland wheels - 20x9.5any idea what wheels those are?
Sweet ride!Saw this at the dealer today and had to share. Good looking truck!
-Blacked Out Grille
-Leveled
-305/55R20 Tires
-Stubby Antenna
-Tinted Windows
For reference, here is a 34" tire on the tremor with a 2.5" level kit. +1 offset on my wheelsSweet ride!
Not digging the tires, I think the ratio of the 305 (12”) wide tires that are 33” tall look too small. Should go to 34”, go big or go home!
Dude, we are thinking the same!For reference, here is a 34" tire on the tremor with a 2.5" level kit. +1 offset on my wheels
What are the size and offset of these wheels? What type of lift is that?Dude, we are thinking the same!
My powerboost lariat on 295/70-18s!
MotoFab 2.5” levelWhat are the size and offset of these wheels? What type of lift is that?
do you have any front and rear shots. Maybe angled as well. I’d love to see the poke of those tires.MotoFab 2.5” level
Cooper discoverer AT3 XLT
295/70-18
Procomp 34 Rockwell 0 offset
The setup looks great, but it does hit the gas mileage 2-3 Mpg
Made a small cut in the fairing, but no rubbing anywhere else, my goal was to have the outside edge of the tires inline with the running boards and it’s pretty close. The poke is tolerable since the tires are 295’s, if they were 305 or 315’s it may be a bit much.do you have any front and rear shots. Maybe angled as well. I’d love to see the poke of those tires.
Do you have any rub, or did you remove the front crash bars?
looks damn good. I have a set of Method 316 in black coming in 18x9 +18mm offset, so a smidge more sucked in than you. I’ll be running Toyo AT3 295/70/18 as well.Made a small cut in the fairing, but no rubbing anywhere else, my goal was to have the outside edge of the tires inline with the running boards and it’s pretty close. The poke is tolerable since the tires are 295’s, if they were 305 or 315’s it may be a bit much.
The methods were my second choice, but I had to cut back somewhere, the cooper tires were buy 3 get 1 free at Midas, and the wheels were buy 3 get 1 free from 4WP so I had an easier time justifying all the upgrades on a $64K truck!!!!looks damn good. I have a set of Method 316 in black coming in 18x9 +18mm offset, so a smidge more sucked in than you. I’ll be running Toyo AT3 295/70/18 as well.
I like your set up, we obviously have similar taste.
Your truck is sick man! Did you have the level kit professionally installed or did you do it yourself?For reference, here is a 34" tire on the tremor with a 2.5" level kit. +1 offset on my wheels
Which leveling kit?Saw this at the dealer today and had to share. Good looking truck!
-Blacked Out Grille
-Leveled
-305/55R20 Tires
-Stubby Antenna
-Tinted Windows
