jmarc71
Didn't bring it in yet as it didn't hapen again. If it starts doing it, i'll definitely do it.Jmarc, did you bring it in again? What was the 2nd fix?
I hope this is the smoking gun.Looks like we got official word it’s a Zone Lighting issue. Got a message from Ford.
I hope so too. This is getting old. I put a fresh charge into the battery 2 days ago and it dropped about a volt since then. I did shut off the zone lighting from center console. Will take another battery reading tomorrow to see if it stops the drain. This is rediculous.I hope this is the smoking gun.
Since my recent battery replacement, all has been well. What I haven’t been able to do yet is to let it sit for 2 or more days without driving it.I hope so too. This is getting old. I put a fresh charge into the battery 2 days ago and it dropped about a volt since then. I did shut off the zone lighting from center console. Will take another battery reading tomorrow to see if it stops the drain. This is rediculous.
I just got a message on my Ford APP that they think the zone lights are draining the battery and to turn them off. They said they would push an update when it was done.Saw this today as well. Was about to post it but you beat me to it. Thanks for sharing with the group. Sounds like Ford is acknowledging the issue.
Thanks. Just checked and got the same message. ?I just got a message on my Ford APP that they think the zone lights are draining the battery and to turn them off. They said they would push an update when it was done.
Ok so I brought it to the dealer for the issue which they said it was because of the power heated mirrors and tow module needed to be re flashed so they did it and when I got my truck back all these settings that I never knew I had all started to work like when I lock the doors the mirrors fold never knew auto start stop has a hold feature again never knew and I played with every button in the truck to shut down things to stop the battery from draining to no avail there’s only one bad thing my 12” display when shutting down goes dim and stays on for 10-15 minutes and during this time it flashes very bright several times like a camera flashRead the manual about how to reset the one touch. Looks really easy.
I just noticed that my screen and rear center console lights are staying slightly on as well, but no flashes.Ok so I brought it to the dealer for the issue which they said it was because of the power heated mirrors and tow module needed to be re flashed so they did it and when I got my truck back all these settings that I never knew I had all started to work like when I lock the doors the mirrors fold never knew auto start stop has a hold feature again never knew and I played with every button in the truck to shut down things to stop the battery from draining to no avail there’s only one bad thing my 12” display when shutting down goes dim and stays on for 10-15 minutes and during this time it flashes very bright several times like a camera flash
